[mapserver-users] QUERYONLY?
Fawcett, David
david.fawcett at moea.state.mn.us
Wed Nov 14 18:23:55 EST 2001
Regina,
I don't believe that the getSymbol() error that you are receiving is related to Vinko's error below.
You are getting an error because the syntax for the SYMBOL object has changed. Look at line 96 of your map file:
#This is the old syntax
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED
END
#This is the new syntax
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED = TRUE #You need to add '= TRUE' to this line
END
Once you make this change, you will most likely get an error in line 137 related to the layer type polyline. You can find a previous post from Steve Lime regarding these changes at:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/0110/msg00374.html
I was just in the process of writing up a list of needed revisions for the 3.5 Demo for Steve.
David.
David J. Fawcett
GIS / Databases
MN Office of Environmental Assistance
520 Lafayette Rd N
St. Paul, MN 55155
651.215.0200
> From: Obe, Regina DND\MIS[SMTP:Regina.Obe.PFD at ci.boston.ma.us]
> Sent: Wednesday, November 14, 2001 4:27 PM
> To: 'v at w.cl'; steve.lime at dnr.state.mn.us
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE: [mapserver-users] QUERYONLY?
> I got a similar error too (not sure if these two are related) - using the
> mapserv35_png_ogr for win32 build 11/7/2001. This was using the itasca demo
> app for 3.5 (I downloaded 10/17/2001) (and my other apps which worked with
> prior version of the mapserv 3.5 exe also give similar behavior. So I was
> wondering if an interim change to specs had taken place during the 3.5
> between 10/19 and now.
> The prior version I was using was a build around 10/19/2001.
> I get an error
> getSymbol(): Symbol definition error. (END):(96)
> (I did modify it a bit to work with my configuration so not the exact demo -
> but just minor changes to paths)
> When trying to use the itasca demo app - dated around 10/17/2001
