[mapserver-users] Is MapServer for me?
Lowell Filak
lfilak at yahoo.com
Mon Nov 19 14:04:56 EST 2001
For task 1: once the coordinates from the GPS are
known it would be easy to submit a manual or automated
request to a CGI/perl script that incorporates the
Mapscript interface to Mapserver. You could submit the
coordinates as arguments to the script and then use
Mapscript to do a QueryByPoint using the coordinates.
The query result can then be used to retrieve the
attribute information for the layer of your choice
which does not need to include a map. Multiple layers
can be queried just as easily.
You will need to keep map projections in mind if your
base data is in a different projection than what comes
in from the GPS (Lat/Lon).
Lowell Filak
--- Klaus Drechsler <drechsler at gmx.net> wrote:
> for a resaerch project I have to do the following
> tasks:
> 1.
> I have a client with a gps receiver. With the
> gps-coordinates I want
> to query a server and get back the location where I
> am (city-name or
> street name or both ...) as ***ascii string***
> (without a map) ...
> 2.
> Like in task one I have a client with a gps
> receiver. This time I send
> the gps-coordinates to a server and want a part of a
> map (as gif/jpg
> or something like that) back where I can see wher I
> am and the near
> neighbourhood.
> Is there (open source) software that can do the
> above tasks?
> I found that GRASS could be what I am searching for
> (I thought), but
> in the GRASS Mailinglist someone told me, that GRASS
> is overkill and I
> should take a look at MapServer...
> So thats why I ask the professionals in this
> mailinglist:
> Can mapserver do the above tasks?
> I think that Task 2 is possible, but I need a
> solution (or ideas) for task 1.
> I hope someone can give me hints on this!
> Bye,
> Klaus
> Zentrum für Graphische Datenverarbeitung (ZGDV)
> Abt. Mobile Informationsvisualisierung
> email: klaus.drechsler at zgdv.de
> zgdv at kdnet.de
__________________________________________________
Do You Yahoo!?
Find the one for you at Yahoo! Personals
http://personals.yahoo.com
