[mapserver-users] referenceMapObj - PHP
Daniel Morissette
morissette at dmsolutions.ca
Wed Nov 21 16:27:43 EST 2001
"Hankley, Chip" wrote:
> I've tried several variations on the following... ($map is set)
> $refmap=$map->referenceMapObj;
> $refmap->set('width', 100);
> or
> $map->referenceMapObj->set('width', 100);
> ...both of these result in Fatal error: Call to a member function on a
> non-object in ...
The class member is actually called "reference", so the following should
work:
$refmap=$map->reference;
or
$map->reference->set('width', 100);
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
