[mapserver-users] referenceMapObj - PHP
Hankley, Chip
Chip.Hankley at GASAI.Com
Wed Nov 21 17:27:37 EST 2001
Daniel...
I must be confused about how this works.
Your comments help, and I can now access the class member and manipulate it
without error... but the size of the image that is produced by
drawReferenceMap() is unaffected.
I have a reference image that is 300x300.
In the mapfile I set it's width / height to 150x150, however the image that
is produced by $img=drawReferenceMap() and $img->saveWebImage is still
300x300
In PHP,
$map->reference->width
returns 150 (as is specified by the mapfile), and if I were to change is by
issuing
$map->reference->set('width', 100)
then
returns 100, but subsequent execution of drawReferenceMap() and saveWebImage
still result in an image that is 300x300.
Am I misunderstanding how this component works? Thanks for your help!
Chip
"Morissette, Daniel" wrote:
>The class member is actually called "reference", so the following should
>work:
> $refmap=$map->reference;
> $refmap->set('width', 100);
>or
> $map->reference->set('width', 100);
