[mapserver-users] symbol size limit?
Rodrigo Cabral
cabral at yadata.net
Thu Nov 22 07:41:42 EST 2001
You can create a circle layer made up of circle shapes with 3 mile radius
based on your original point layer. This way you don't have to worry about
calculating the right size of your symbols. Circle shapes are two-point
shapes, which define the bounding box (left,top)-(right,bottom) for the
circle. Am I right Steve?
Rod.
----- Original Message -----
From: "Jensen, Hannah ERDC-CRREL-NH" <Hannah.Jensen at erdc.usace.army.mil>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, November 20, 2001 4:23 PM
Subject: [mapserver-users] symbol size limit?
Hi, all. I'm trying to change the size of a symbol by changing the map file
parameter via the URL. It seems to work up to a certain size, but not
beyond it. It looks as if the limit is around 100 pixels. Is there a
symbol size limit in MapServer?
Maybe there's a better way to do what I'm trying to do. I want to draw a 3
mile radius circle around a point. I'm calculating the appropriate symbol
size based on the map scale right now, but am open to other suggestions. I
saw a few posts on this topic regarding the use of layer type circle, but I
couldn't get it to work. Any ideas? Thanks!
Cheers,
Hannah
Hannah Jensen
(603) 646-4145
Remote Sensing / GIS Center
Cold Regions Research and Engineering Lab (CRREL)
US Army Corps of Engineers
72 Lyme Rd, Hanover, NH 03755-1290
