[mapserver-users] problems with the reference map
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Nov 28 13:56:00 EST 2001
That almost implies problems with the reference map defiinition. That is, the extent is wrong or perhaps the size values don't actually match the image you're using. Those are certainly the first places to check.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Doyon, Jean-Francois" <Jean-Francois.Doyon at ccrs.nrcan.gc.ca> 11/27/01 02:55PM >>>
Hello,
I'm having problems with the drawing of the box on the reference map ... It
draws a bit "off" of where it should be, and the more I zoom in, the worst
it gets!
I checked other tools I've built, and it works fine there.
The map and reference map share the same inital extent, and the image size
is a perfect fraction of the main map, so everything should fit ok ...
The only thing that comes to mind would be differences in the underlying
data ... has anybody experienced this before?
Thank you,
Jean-François Doyon
Internet Service Development and Systems Support
GeoAccess Division
Canadian Center for Remote Sensing
Natural Resources Canada
http://atlas.gc.ca
Phone: (613) 992-4902
Fax: (613) 947-2410
