[mapserver-users] problems with the reference map
Rodrigo Cabral cabral at yadata.net
Wed Nov 28 17:57:55 PST 2001
I guess here it's your solution... Maybe we should do a HOWTO on this:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/01
11/msg00078.html
and
11/bin00001.bin
The PHP reference map generator needs a fix though, need to put 'set width &
height' before 'setextent', like this:
$map->setextent( $minx, $miny, $maxx, $maxy );
$map->set( 'width' , $width );
$map->set( 'height' , $height );
changes to:
Rod.
----- Original Message -----
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
To: <Jean-Francois.Doyon at ccrs.nrcan.gc.ca>;
<mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, November 28, 2001 4:56 PM
Subject: Re: [mapserver-users] problems with the reference map
That almost implies problems with the reference map defiinition. That is,
the extent is wrong or perhaps the size values don't actually match the
image you're using. Those are certainly the first places to check.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Doyon, Jean-Francois" <Jean-Francois.Doyon at ccrs.nrcan.gc.ca> 11/27/01
02:55PM >>>
Hello,
I'm having problems with the drawing of the box on the reference map ... It
draws a bit "off" of where it should be, and the more I zoom in, the worst
it gets!
I checked other tools I've built, and it works fine there.
The map and reference map share the same inital extent, and the image size
is a perfect fraction of the main map, so everything should fit ok ...
The only thing that comes to mind would be differences in the underlying
data ... has anybody experienced this before?
Thank you,
Jean-François Doyon
Internet Service Development and Systems Support
GeoAccess Division
Canadian Center for Remote Sensing
Natural Resources Canada
http://atlas.gc.ca
Phone: (613) 992-4902
Fax: (613) 947-2410
More information about the MapServer-users mailing list
