[mapserver-users] query templates with Postgis
Paul Ramsey
pramsey at refractions.net
Wed Oct 3 11:48:42 EDT 2001
My pseudo-informed guess is that Dave hardcoded a size into his
character handlers, and you just found it. If I am right, he'll have a
fix into the CVS version of mapserver before the end of the day... if I
am wrong, he will chastise me publicly.
"Ellis Robin (Bundaberg)" wrote:
> Hi,
> I've got several layers of data exhibiting and querying in a
> recent nightly build of Mapserver. When I do extract attributes from a
> Postgis layer through a standard Mapserver query template I'm only
> getting the first 31 characters from any field returned. This same data
> can be accessed through a PostgreSQL environment revealing all
> characters of reasonably long strings. Also, the same data set accessed
> as a shapefile will return the full string in a standard Mapserver query
> template.
> Am I likely to need to change the config of Mapserver, or is there some
> limitation between Postgis and Mapserver that I won't be able to
> overcome simply?
> Thanks
> Rob.
> Robin Ellis
> Department of Natural Resources and Mines
> Burnett District
> +61 7 4131 5771
> Robin.Ellis at dnr.qld.gov.au
> The information in this e-mail together with any attachments is
> intended only for the person or entity to which it is addressed
> and may contain confidential and/or privileged material.
> Any form of review, disclosure, modification, distribution
> and/or publication of this e-mail message is prohibited.
> If you have received this message in error, you are asked to
> inform the sender as quickly as possible and delete this message
> and any copies of this message from your computer and/or your
> computer system network.
