[mapserver-users] query templates with Postgis
Ellis Robin (Bundaberg)
Robin.Ellis at dnr.qld.gov.au
Wed Oct 3 00:25:00 EDT 2001
I've got several layers of data exhibiting and querying in a
recent nightly build of Mapserver. When I do extract attributes from a
Postgis layer through a standard Mapserver query template I'm only
getting the first 31 characters from any field returned. This same data
can be accessed through a PostgreSQL environment revealing all
characters of reasonably long strings. Also, the same data set accessed
as a shapefile will return the full string in a standard Mapserver query
template.
Am I likely to need to change the config of Mapserver, or is there some
limitation between Postgis and Mapserver that I won't be able to
overcome simply?
Thanks
Rob.
Robin Ellis
Department of Natural Resources and Mines
Burnett District
+61 7 4131 5771
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
