[mapserver-users] RE: Compiling MS on Win32+SDE
j1mmm
j1mmm at hotmail.com
Wed Oct 10 01:20:14 EDT 2001
HI Steve and Lists,
i got similar problem like Egon Kuster. i finished to compile MS35+SDE on NT but when i try SDE support, i got following error.
now this problem in WIN are in progress or not. Do you have the way to solve my problem?? . i 'm not sure i configured mapfile for connection SDE correct or not so it 's attached.
Regards and Thank
j1mmm
------window pop up--------
mapserv.exe - Application Error
The Exception Illegal Instruction
An attempt was made to execute an illegal instruction.
(0xc000001d) occurred in the application at location 0x009855a0.
LAYER
NAME "ProvincesOutline"
TYPE line
STATUS DEFAULT
CONNECTIONTYPE sde
CONNECTION "trang,esri_sde,oie,sde,password"
DATA "OIE.SDE.PROVINCES,shapeID"
CLASS
Name "Provinces"
COLOR 1 1 1
TEMPLATE "queryProvince.html"
END
END
a.. To: "'Eduin Yesid Carrillo'" <yecarrillo at hotmail.com>, mapserver-users at lists.gis.umn.edu
b.. Subject: RE: Compiling MS on Win32+SDE
c.. From: "Kuster, Egon" <Egon.Kuster at dsto.defence.gov.au>
d.. Date: Fri, 23 Feb 2001 08:59:59 +1030
Yeah I have been able to compile mapserver with SDE support in win32 but
there are other problems after you have the program compiled and running.
When you try and use a normal shapefile the compiled program works fine but
as soon as you try and use the SDE support you get the following error:
The instruction at "0x00423d96" reference memory at "0x00000004". The memory
could not be "read"
I currently have Stephen Lime who is working for University of Minnesota to
look into this problem, if you would like more information drop stephen a
line on steve.lime at dnr.state.mn.us
So here is where I stand, yes I can get it to compile and run on win32 but
when you use the SDE support a memory error is produced.
Sorry but that is where it is at the moment.
Egon Kuster
Defence Science & Technology Organisation
Information Technology Division
Phone: +61 8 8259 5175
Fax: +61 8 8259 5619
-----Original Message-----
From: Eduin Yesid Carrillo [mailto:yecarrillo at hotmail.com]
Sent: Thursday, 22 February 2001 11:46 AM
To: mapserver-users at lists.gis.umn.edu
Subject: Compiling MS on Win32+SDE
This question was posted before without concrete answers:
I am trying to compile mapserver in my win32 pc with sde support without
success.
Somewhere in the source, I find the need of this client libraries:
Include files: sdetype.h and sdeerno.h in
$SDE_DIR/arcsde/coverages/include/sdetype.h
$SDE_DIR/include/sdetype.h
$SDE_DIR/sdetype.h
Client libs: libsde30.a (sde 3.0) or libsde80.a (arcSDE 8) in
$SDE_DIR/lib/libsde80.a
$SDE_DIR/libsde80.a
I have the client cds for:
sde 3.0.2
sde 3.0.2.1
sde 3.0.2.2
arcsde 8.0 for Oracle 8i
Installing this clients I found this common structure:
sdeexe30(or ora8iexe)
|-------bin
|-------include
| |-----sdeerno.h
| |-----sdetype.h
|-------lib
| |-----sde30.lib (or sde80.lib)
The questions...
Is sde30.lib (or sde80.lib)equivalent to libsde30.a (or libsde80.a) for
compile?
Somebody in the list have compiled MS with SDE enabled for Win32?
Ingeniero Civil
#ICQ 14323531
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011010/49d9654a/attachment.html
