[mapserver-users] RE: Compiling MS on Win32+SDE
Steve Lime
steve.lime at dnr.state.mn.us
Wed Oct 10 12:22:59 EDT 2001
Unfourtunately I don't have a solution. I have no access to SDE on the
windows platform. I hope another lister can step in and help. Do you
have access to a Linux or Unix machine? It would be helpful to see if
this layer works on non-Windows platforms or not.
Steve
j1mmm wrote:
> HI Steve and Lists,
> i got similar problem like Egon Kuster. i finished to compile MS35+SDE
> on NT but when i try SDE support, i got following error.
> now this problem in WIN are in progress or not. Do you have the way to
> solve my problem?? . i 'm not sure i configured mapfile for connection
> SDE correct or not so it 's attached.
> Regards and Thankj1mmmj1mmm at hotmail.com------window pop
> up--------mapserv.exe - Application Error The Exception Illegal
> Instruction
> An attempt was made to execute an illegal instruction.
> (0xc000001d) occurred in the application at location
> 0x009855a0.------------------------------------LAYER
> NAME "ProvincesOutline"
> TYPE line
> STATUS DEFAULT
> CONNECTIONTYPE sde
> CONNECTION "trang,esri_sde,oie,sde,password"
> DATA "OIE.SDE.PROVINCES,shapeID"
> CLASS
> Name "Provinces"
> COLOR 1 1 1
> TEMPLATE "queryProvince.html"
> END
> END
> * To: "'Eduin Yesid Carrillo'" <yecarrillo at hotmail.com>,
> mapserver-users at lists.gis.umn.edu
> * Subject: RE: Compiling MS on Win32+SDE
> * From: "Kuster, Egon" <Egon.Kuster at dsto.defence.gov.au>
> * Date: Fri, 23 Feb 2001 08:59:59 +1030
> Yeah I have been able to compile mapserver with SDE support in win32 but
> there are other problems after you have the program compiled and running.
> When you try and use a normal shapefile the compiled program works fine but
> as soon as you try and use the SDE support you get the following error:
> The instruction at "0x00423d96" reference memory at "0x00000004". The memory
> could not be "read"
> I currently have Stephen Lime who is working for University of Minnesota to
> look into this problem, if you would like more information drop stephen a
> line on steve.lime at dnr.state.mn.us
> So here is where I stand, yes I can get it to compile and run on win32 but
> when you use the SDE support a memory error is produced.
> Sorry but that is where it is at the moment.
> Egon Kuster
> Defence Science & Technology Organisation
> Information Technology Division
> Phone: +61 8 8259 5175
> Fax: +61 8 8259 5619
> -----Original Message-----
> From: Eduin Yesid Carrillo [mailto:yecarrillo at hotmail.com]
> Sent: Thursday, 22 February 2001 11:46 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Compiling MS on Win32+SDE
> This question was posted before without concrete answers:
> I am trying to compile mapserver in my win32 pc with sde support without
> success.
> Somewhere in the source, I find the need of this client libraries:
> Include files: sdetype.h and sdeerno.h in
> $SDE_DIR/arcsde/coverages/include/sdetype.h
> $SDE_DIR/include/sdetype.h
> $SDE_DIR/sdetype.h
> Client libs: libsde30.a (sde 3.0) or libsde80.a (arcSDE 8) in
> $SDE_DIR/lib/libsde80.a
> $SDE_DIR/libsde80.a
> I have the client cds for:
> sde 3.0.2
> sde 3.0.2.1
> sde 3.0.2.2
> arcsde 8.0 for Oracle 8i
> Installing this clients I found this common structure:
> sdeexe30(or ora8iexe)
> |-------bin
> |-------include
> | |-----sdeerno.h
> | |-----sdetype.h
> |-------lib
> | |-----sde30.lib (or sde80.lib)
> The questions...
> Is sde30.lib (or sde80.lib)equivalent to libsde30.a (or libsde80.a) for
> compile?
> Somebody in the list have compiled MS with SDE enabled for Win32?
> Ingeniero Civil
> #ICQ 14323531
