[mapserver-users] Mapscript / Projection Question
Paul Ramsey
pramsey at refractions.net
Wed Oct 10 14:12:42 EDT 2001
OK, to start with, I have a map file with a default planar projection.
$map->{extent}->{minx} gives me a nice planar value : 167053
I do a $map->setProjection("init=epgs:4269") where EPSG 4269 is a
lat/lon projection.
$map->{extent}->{minx} *still* gives me a nice planar value : 167053
What precisely does setProjection effect? The output image only? If so,
how do I specify an input extent? In the default projection only? I
*thought* the correct chain of operations was like this:
- Mapserver with default projection P1
- Given desired extent E1 in projection P2
- $map->setProjection(P2)
- $map->{extent} = E1
- Given that one wants output in projection P3
- $map->setProjection(P3)
- $map->draw()
So
1) how to I set the projection the output image will be generated in?
2) how do I specify an image extent, given that I am doing something
like 1) ?
Thanks,
Paul
