[mapserver-users] ms_newLayerObj (fwd)
Assefa Yewondwossen
assefa at dmsolutions.ca
Wed Oct 10 16:41:52 EDT 2001
Hi There,
I just tested the creation of layers dynamically using php/mapscript and It seems to
work fine.
From the code bellow I think the only problem in your case is the way you define the
colors. You should do soemthing like this :
$newclass = ms_newClassObj($newlay);
$colorId = $map->addColor(0, 0, 255);
$newclass->set("outlinecolor", $colorId);
I am assumoing here that all the seeting of the other parameters (like data, ...) are
correct.
Hope it helps,
Later,
teb wrote:
> ------------- Begin Forwarded Message -------------
> From: Øyvind Idland <oyvind.idland at powelgemini.no>
> To: <mapserver-info at lists.gis.umn.edu>
> Subject: ms_newLayerObj
> Date: Mon, 8 Oct 2001 16:18:32 +0200
> MIME-Version: 1.0
> X-Priority: 3
> X-MSMail-Priority: Normal
> X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4133.2400
> Content-Transfer-Encoding: 8bit
> X-MIME-Autoconverted: from quoted-printable to 8bit by mallit.fr.umn.edu id JAA14289
> Hello
> I am currently testing Mapscript 3.4 with php 4.05, running as cgi under IIS.
> Since I want to use points/objects from a database (via odbc), i want to create
> layers on the fly. For some reason, the layer refuses to draw.
> I used following lines:
> $map = ms_newMapObj("C:\inetpub\wwwroot\oi\oi.map");
> $newlay = ms_newLayerObj($map);
> $newlay->set("name", "db_layer");
> $newlay->type = MS_LAYER_POINT;
> $newlay->status = MS_ON;
> $newclass->outlinecolor = 0;
> $newclass->symbol = 3;
> $newclass->size = 10;
> and then the nessesary database / point adding stuff.
> (This works fine if I define the layer in the .map file)
> There are already 2 other layers on the map, so this is the 3rd layer.
> $map->numlayers returns 2, (there should be 3 ?) and $newlay->index returns 1.
> Is this a bug ? :)
> Anyway, thanks for a powerful tool.
> Oyvind Idland, Powel Gemini A/S
> mailto:oyvind.idland at powelgemini.no
> ------------- End Forwarded Message -------------
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056
