[mapserver-users] ArcIMS Emulations
Stephen Lime
steve.lime at dnr.state.mn.us
Tue Oct 16 11:46:18 EDT 2001
or better yet add a arcXML parser module to the C source (using expeat?) and then it
could be made available via the CGI and all scripting interfaces...
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Kieran J. Ames" <kames at keyspanenergy.com> 10/16/01 08:44AM >>>
While PHP is a popular thing, I'd like to cast my vote to maintain the Perl
development.
(Call me old-fashioned!)
Kieran
Brian Fischer wrote:
> Paul,
> Wow, it works great and it is blazin fast. It works just like you are
> connecting to Geography Network. This adds a big selling point to
> Mapserver. It is hard sometimes to convince clients that MapServer is
> the better choice over other IMS's. This was one of the sticking points
> that clients would bring up. This is great news. Would there be any
> limitations to what OS this script could run on? I run MapServer on
> Windows. I know Perl is not the popular choice of MapServer/MapScript
> users that use Windows. Is a port to PHP possible?
> Another thing I commonly run into is clients that store all their
> imagery in Mr. Sid format. I know there has been some discussion in the
> past about the possibility of adding Mr. SID support to MapServer and
> the conclusion was it would not be that easy to do. Has anyone else
> found a creative solution to convincing clients that have imagery stored
> in Mr. SID to use MapServer over another IMS that supports Mr. SID
> imagery?
> Great work Paul.
> Have a good day,
> Brian
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Friday, October 12, 2001 4:35 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] ArcIMS Emulations
> Hey, all you people with Arc8. Open up ArcCatalog, go to 'Create
> connection to internet server...' and enter
> 'http://mapserver.refractions.net' into the URL box. Then drag one of
> the services into ArcMap. Voila! What is the big deal? That ain't no
> ArcIMS server on that machine: it is Mapserver, with a perl front-end to
> make it act like ArcIMS.
> This is dependant on some hacks I've put into my version of Mapserver.
> It also is missing support for some of the ESRI 'standard' projection
> ids. When the projection stuff is standard in proj4 (Frank is looking at
> it) and I have got my hacks cleanly into mapserver/mapscript I'll
> release the script. Maybe by then it will also do client preferences for
> rendering too... oooooh... (and have more elegant XML handling...)
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
