[mapserver-users] Problem fixed
gispmpf at zipmail.com.br
Wed Oct 17 23:44:44 EDT 2001
gispmpf at zipmail.com.br wrote:
> Thanks dave
> I have tried your changes but i steel have the same problem
> the: psql -U postgres teste
> work ok and if i type
> select linha from teste where id=1;
> in the psql terminal work ok too.
> but the following mapfile layer dont...
>I have no idea why its not working. What version of postgresql >are you
>running? Do you have any other versions installed? Is the libpq >the
>correct version?
>Here are two fixes:
>1. remove the "host=localhost" portion of the connection string
>2. start the postmaster with the "-i" option to enable TCP/IP
>connections
Thanks dave this fix the problem.
Best regards
João
___________________________________________________________
http://www.zipmail.com.br O e-mail que vai aonde você está.
