[mapserver-users] OGC and Mapserver
Rob Atkinson
rob at socialchange.net.au
Thu Oct 18 08:26:50 EDT 2001
Social Change Online has set up MapServ 3.5 under Linux and found it pretty
stable and OGC compliance has been good.
It is a significant improvement in its ability to perform reprojections on the
fly controlled by OGC parameters.
The feature_info issue is the current major limitation - we really need to be
able to generate our own GML response schemas to get much value out of this.
Rob Atkinson
"Hockaday, John" wrote:
> Hi,
> I want to implement a simple OpenGIS compliant Web Map Service using
> Mapserver to test the WMS concepts. I believe that Mapserver version 3.5 is
> capable of doing this however, I've been waiting for 3.5 to be stable and
> beyond the nightly builds before I attempt this project. I don't have CVS
> just RCS. I therefore, have the following questions:
> 1. Has anyone set up a simple OpenGIS compliant WMS using mapserv? If so
> how difficult was it and can you supply any examples?
> 2. Is Mapserver version 3.5 stable enough for me to confidently implement
> and smoothly run a WMS and if not when will it be stable enough.
> 3. Is it easy to convert 3.4 mapfiles format into 3.5 mapfiles format?
> Thanks in advance for your replies.
> John Hockaday
Type: text/x-vcard
Desc: Card for Rob Atkinson
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011018/287352ab/rob.vcf
