[mapserver-users] Win 32 v3.5 Nightly - Proj4 Support
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 19 09:10:47 EDT 2001
Andrew Hallam wrote:
> Hi All,
> When we first installed 3.5 (4-Sep-2001) we also put the epsg file in
> c:\proj - it worked as expected. After downloading the latest win32 nightly
> build we are getting the following error:
> msProcessProjection(): no system list, errno 2Y
> This message appears to originate in the Proj4 code, and occurs with all the
> Win32 builds. Are we missing something simple, or has something changed?
Andrew,
There have been a few changes in the default PROJ.4 build configuration.
I suspect you need to put them in C:\PROJ\NAD now instead. Note that you
can always set the PROJ_LIB environment variable to point to the files that
PROJ.4 looks for.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
