[mapserver-users] Win 32 v3.5 Nightly - Proj4 Support
Pericles S. Nacionales
pnaciona at gis.umn.edu
Fri Oct 19 10:04:58 EDT 2001
Andrew,
Frank is right. The correct place to put the epsg file is
C:\PROJ\NAD. I've recompiled the distributions and will have it available
this afternoon (as soon as I get to school).
-Perry
On Fri, 19 Oct 2001, Frank Warmerdam wrote:
> Andrew Hallam wrote:
> > Hi All,
> > When we first installed 3.5 (4-Sep-2001) we also put the epsg file in
> > c:\proj - it worked as expected. After downloading the latest win32 nightly
> > build we are getting the following error:
> > msProcessProjection(): no system list, errno 2Y
> > This message appears to originate in the Proj4 code, and occurs with all the
> > Win32 builds. Are we missing something simple, or has something changed?
> Andrew,
> There have been a few changes in the default PROJ.4 build configuration.
> I suspect you need to put them in C:\PROJ\NAD now instead. Note that you
> can always set the PROJ_LIB environment variable to point to the files that
> PROJ.4 looks for.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
