[mapserver-users] Split large tiffs (topos) like TopoZone
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Oct 19 10:16:05 EDT 2001
Couple of things to add... 1) Dan Morissette has added cascading mapserver support to MapServer 3.5 release. 2) I have an older version of the mapplet code that takes 2 images and overlays them, plus gives you the box zooming. It was written for a similar an application- MapServer over LandSat, where the images came from two different servers. I haven't used it much since raster support was added to MapServer but with just a little update it would work.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Ed McNierney" <ed at topozone.com> 10/19/01 08:39 AM >>>
Allan -
I would urge anyone considering the "CSS approach" you describe to do so
with extreme caution. This is remarkably difficult to get working
properly across a reasonable set of browser platforms. Everyone's done
it differently, the bugs are different in each release, and it's just a
nightmare. There's a very good reason why the map on the Digital Earth
page you mention is at the upper-left corner of the page - it's really
hard to make it work anywhere else on the page!
Having "been there, done that", I would really recommend that anyone
considering that approach instead use a small Java applet to load the
images and display them. Your compatibility problems will be greatly
reduced.
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Allan Doyle [mailto:adoyle at intl-interfaces.com]
Sent: Friday, October 19, 2001 8:22 AM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Split large tiffs (topos) like TopoZone
I think the original question/need was to be able to have DRGs "like
TopoZone's" that John Arthur could layer his own data on top of.
If, indeed, he meant that he wants to layer his data on top of
TopoZone's data, then since we learned (also in this thread) that
TopoZone has a WMS, then he's home free. The idea behind WMS was to
allow precisely this: "Map A" from source "A" can be layered onto "Map
B" from source "B" without having to copy all the data from "A" to "B"
or vice versa. This can be done at the client end using CSS tricks with
layers - i.e. the client sends out two requests, one to WMS A and one to
WMS B and can layer the result. Or it can be done using "Cascading WMS"
techniques - WMS A behaves as a client to WMS B, pulls WMS B's layers in
on demand, and produces the layered map for WMS A.
http://viewer.digitalearth.gov/ is a great example of the CSS approach.
http://www.cubewerx.com/demo/cubeview/cubeview.cgi is the original and
probably the best current example of the cascading approach.
Also, not to be heretical in the mapserver-users list, but there's an
open source implementation of a WMS geared to displaying from large
image bases called the MIT OrthoServer at
http://tull.mit.edu/orthoserver/ You can use it for the image layers
and the mapserver for the other layers and cascade up through the
mapserver.
Allan
Stephen Lime wrote:
> Ed is quite correct (he should be, it's his site). I did the same
thing for Minnesota (maps.dnr.state.mn.us/tomo, ~300,000 images) and it
works very well. That script is simple perl script that doesn't use
MapServer. However, I did use perl and MapScript to compute the 300k
images (I think I still have the script if anyone want to take a look).
Took a day. Can MapServer and the TOMO server work together? Possibly
but you'd be bound by the non-MapServer application because of the
nature of the underlying data.
> Again, TOMO and TopoZone are built to serve one layer very fast, but
I've been using the exact same datasets (quad-based DRGs) that the
little images were computed from in a tiled fashion to support a much
broader range of scales and applications with great success and by
managing a few thousand images instead of a few hundred thousand. I can
only imagine what the TopoZone folks go through with 17 million images
and all the projection headaches.
> Steve
> Stephen Lime
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Ed McNierney" <ed at topozone.com> 10/18/01 19:42 PM >>>
> Folks -
> I've already mentioned to John privately that I have set up a WMS
server
> for topographic maps and would be interested in working with folks who
> would either like to use WMS "end-point" clients or use MapServer as a
> WMS client for these data layers. These will shortly be available as
a
> subscription service from TopoZone, and I could use some guinea pigs.
> If you're very cooperative, I've got some nice 1-meter DOQ data you
can
> use, too <g>. Send email if you're interested; you'll be able to get
> complete DRG or DOQ base maps for your MapServer applications without
> buying data or disk to put it on!
> On the original point of chopping up rasters into little tiles, don't
> get carried away. TopoZone's current image architecture is designed
to
> do one very, very specific task very quickly. The entire "map server"
> for topozone.com (just the map-serving system, not the Web site) is
six
> lines of ASP VBScript code; everything is precomputed and prebuilt,
and
> all we serve are small image tiles at one of four fixed zoom levels.
> The tiles are small so you can scroll the map in whole-tile increments
> while still providing the user a reasonable degree of centering
control.
> The HARD part was generating all those tiles from the hodgepodge of
> source DRG data - serving them is trivial.
> I would NOT recommend a similar approach for MapServer applications -
> the tiles are WAY too small. Besides the administrative hassles (I've
> got over 17 million of the little buggers to keep track of) the
> disk-seeking overhead is not worth it. You can construct a very nice
> MapServer system using much larger files. We're currently managing a
> few applications with topographic base maps, are we're storing one
quad
> (one DRG) per file; that means each TIFF file is several megabytes.
> There's NO problem with performance IF you structure the data
carefully.
> I could very easily use larger TIFF images, but there's no benefit for
> me to do that - having one output TIFF image for every input DRG makes
> updates, bug fixes, and administration much easier.
> - Ed
> Ed McNierney
> Chief Mapmaker
> TopoZone.com
> From: Arthur, John [mailto:John.Arthur at voicestream.com]
> Sent: Thursday, October 18, 2001 6:15 PM
> To: 'kenboss'; Arthur, John
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE: [mapserver-users] Split large tiffs (topos) like TopoZone
> Hmm,.. I seams my mapserver won't display rasters,...
> I'm using 3.5 w/php_mapscript on windows2000. It(phpinfo) says tiff
was
> compiled in, and I get no errors.
> I'm using the ".wld" extention and also tried TileIndex through
> shapefiles,.. Any ideas?
> -John
> From: kenboss [mailto:kenboss at dilbert.dnr.state.mn.us]
> Sent: Thursday, October 18, 2001 4:49 PM
> To: John.Arthur at voicestream.com
> Right, you'd lose the georeferencing with the ImageMagick approach.
If
> you're a
> programmer, it shouldn't be too hard to do using one of the GDAL APIs
> (C,
> C++,
> or Python). If you're only a wannabe programmer like myself, you
might
> still be
> able to hack one of the apps distributed with GDAL (such as
> gdal_translate)
> to
> get what you need. See http://www.remotesensing.org/gdal/
> --Ken
> Ken Boss
> Digital Image Analysis / Web Stuff Forestry Resource Assessment
> kenboss at dilbert.dnr.state.mn.us Minnesota Dept. of Natural
> Resources
> Voice: 218 327 4449 ext. 237 413 SE 13th Street
> Fax: 218 327 4517 Grand Rapids, MN 55744
> USA
> www.ra.dnr.state.mn.us
> > Yes, but what about the world file(.twf)?
> > - John
> > From: Stephen Woodbridge [mailto:woodbri at mediaone.net]
> > Sent: Thursday, October 18, 2001 4:21 PM
> > To: Arthur, John
> > Cc: Mapserver-Users at Lists. Gis. Umn. Edu (E-mail)
TopoZone
> > I believe you could do that with ImageMagick and Perl to automate
it.
> > You should be able to chop up each of your large maps into n x m
> tiles.
> > -Stephen Woodbridge
> > http://web-maps.org
> > "Arthur, John" wrote:
> > > I would like to use topo quads in my MapServer, but it would take
> forever
> > to
> > > export each quad from Delorme's 3D topoquads. So I exported large
> 150 mb
> > > files instead. Is there a way to split these up into smaller
files
> or
> > just
> > > to display the large tiff in MapServer faster. We would like
> something
> > like
> > > what TopoZone.com has (Mad props to you guys @ TopoZone.com), but
> layer
> > our
> > > own data on top.
> > > John Arthur
> > > RF Technician
> > > Office: (757) 490-7221
> > > Cellular: (757) 692-1515
> > > Email: john.arthur at voicestream.com
> > > _~-^-~_
> > > VoiceStream
> > > W I R E L E S S
Allan Doyle http://www.intl-interfaces.com
