[mapserver-users] Split large tiffs (topos) like TopoZone
Cameron Shorter
cameron at socialchange.net.au
Sat Oct 20 00:04:05 EDT 2001
http://geotools.sourceforge.net is a java applet which now has WMS
support.
It can take layers from multiple WMS servers and display them
seperately.
However, code is still beta. Documentation for WMS support is still
light.
The applet is fairly big (around 200K).
Contact me if you want more details, or download the source from CVS.
Stephen Lime wrote:
> Couple of things to add... 1) Dan Morissette has added cascading mapserver support to MapServer 3.5 release. 2) I have an older version of the mapplet code that takes 2 images and overlays them, plus gives you the box zooming. It was written for a similar an application- MapServer over LandSat, where the images came from two different servers. I haven't used it much since raster support was added to MapServer but with just a little update it would work.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Ed McNierney" <ed at topozone.com> 10/19/01 08:39 AM >>>
> Allan -
> I would urge anyone considering the "CSS approach" you describe to do so
> with extreme caution. This is remarkably difficult to get working
> properly across a reasonable set of browser platforms. Everyone's done
> it differently, the bugs are different in each release, and it's just a
> nightmare. There's a very good reason why the map on the Digital Earth
> page you mention is at the upper-left corner of the page - it's really
> hard to make it work anywhere else on the page!
> Having "been there, done that", I would really recommend that anyone
> considering that approach instead use a small Java applet to load the
> images and display them. Your compatibility problems will be greatly
> reduced.
> - Ed
> Ed McNierney
> Chief Mapmaker
> TopoZone.com
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Allan Doyle [mailto:adoyle at intl-interfaces.com]
> Sent: Friday, October 19, 2001 8:22 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] Split large tiffs (topos) like TopoZone
> I think the original question/need was to be able to have DRGs "like
> TopoZone's" that John Arthur could layer his own data on top of.
> If, indeed, he meant that he wants to layer his data on top of
> TopoZone's data, then since we learned (also in this thread) that
> TopoZone has a WMS, then he's home free. The idea behind WMS was to
> allow precisely this: "Map A" from source "A" can be layered onto "Map
> B" from source "B" without having to copy all the data from "A" to "B"
> or vice versa. This can be done at the client end using CSS tricks with
> layers - i.e. the client sends out two requests, one to WMS A and one to
> WMS B and can layer the result. Or it can be done using "Cascading WMS"
> techniques - WMS A behaves as a client to WMS B, pulls WMS B's layers in
> on demand, and produces the layered map for WMS A.
> http://viewer.digitalearth.gov/ is a great example of the CSS approach.
> http://www.cubewerx.com/demo/cubeview/cubeview.cgi is the original and
> probably the best current example of the cascading approach.
> Also, not to be heretical in the mapserver-users list, but there's an
> open source implementation of a WMS geared to displaying from large
> image bases called the MIT OrthoServer at
> http://tull.mit.edu/orthoserver/ You can use it for the image layers
> and the mapserver for the other layers and cascade up through the
> mapserver.
> Allan
> Stephen Lime wrote:
> > Ed is quite correct (he should be, it's his site). I did the same
> thing for Minnesota (maps.dnr.state.mn.us/tomo, ~300,000 images) and it
> works very well. That script is simple perl script that doesn't use
> MapServer. However, I did use perl and MapScript to compute the 300k
> images (I think I still have the script if anyone want to take a look).
> Took a day. Can MapServer and the TOMO server work together? Possibly
> but you'd be bound by the non-MapServer application because of the
> nature of the underlying data.
> > Again, TOMO and TopoZone are built to serve one layer very fast, but
> I've been using the exact same datasets (quad-based DRGs) that the
> little images were computed from in a tiled fashion to support a much
> broader range of scales and applications with great success and by
> managing a few thousand images instead of a few hundred thousand. I can
> only imagine what the TopoZone folks go through with 17 million images
> and all the projection headaches.
> > Steve
> > Stephen Lime
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-297-2937
> > >>> "Ed McNierney" <ed at topozone.com> 10/18/01 19:42 PM >>>
> > Folks -
> > I've already mentioned to John privately that I have set up a WMS
> server
> > for topographic maps and would be interested in working with folks who
> > would either like to use WMS "end-point" clients or use MapServer as a
> > WMS client for these data layers. These will shortly be available as
> a
> > subscription service from TopoZone, and I could use some guinea pigs.
> > If you're very cooperative, I've got some nice 1-meter DOQ data you
> can
> > use, too <g>. Send email if you're interested; you'll be able to get
> > complete DRG or DOQ base maps for your MapServer applications without
> > buying data or disk to put it on!
> > On the original point of chopping up rasters into little tiles, don't
> > get carried away. TopoZone's current image architecture is designed
> to
> > do one very, very specific task very quickly. The entire "map server"
> > for topozone.com (just the map-serving system, not the Web site) is
> six
> > lines of ASP VBScript code; everything is precomputed and prebuilt,
> and
> > all we serve are small image tiles at one of four fixed zoom levels.
> > The tiles are small so you can scroll the map in whole-tile increments
> > while still providing the user a reasonable degree of centering
> control.
> > The HARD part was generating all those tiles from the hodgepodge of
> > source DRG data - serving them is trivial.
> > I would NOT recommend a similar approach for MapServer applications -
> > the tiles are WAY too small. Besides the administrative hassles (I've
> > got over 17 million of the little buggers to keep track of) the
> > disk-seeking overhead is not worth it. You can construct a very nice
> > MapServer system using much larger files. We're currently managing a
> > few applications with topographic base maps, are we're storing one
> quad
> > (one DRG) per file; that means each TIFF file is several megabytes.
> > There's NO problem with performance IF you structure the data
> carefully.
> > I could very easily use larger TIFF images, but there's no benefit for
> > me to do that - having one output TIFF image for every input DRG makes
> > updates, bug fixes, and administration much easier.
> > - Ed
> > Ed McNierney
> > Chief Mapmaker
> > TopoZone.com
> > From: Arthur, John [mailto:John.Arthur at voicestream.com]
> > Sent: Thursday, October 18, 2001 6:15 PM
> > To: 'kenboss'; Arthur, John
> > Cc: mapserver-users at lists.gis.umn.edu
> > Subject: RE: [mapserver-users] Split large tiffs (topos) like TopoZone
> > Hmm,.. I seams my mapserver won't display rasters,...
> > I'm using 3.5 w/php_mapscript on windows2000. It(phpinfo) says tiff
> was
> > compiled in, and I get no errors.
> > I'm using the ".wld" extention and also tried TileIndex through
> > shapefiles,.. Any ideas?
> > -John
> > From: kenboss [mailto:kenboss at dilbert.dnr.state.mn.us]
> > Sent: Thursday, October 18, 2001 4:49 PM
> > To: John.Arthur at voicestream.com
> > Right, you'd lose the georeferencing with the ImageMagick approach.
> If
> > you're a
> > programmer, it shouldn't be too hard to do using one of the GDAL APIs
> > (C,
> > C++,
> > or Python). If you're only a wannabe programmer like myself, you
> might
> > still be
> > able to hack one of the apps distributed with GDAL (such as
> > gdal_translate)
> > to
> > get what you need. See http://www.remotesensing.org/gdal/
> > --Ken
> > Ken Boss
> > Digital Image Analysis / Web Stuff Forestry Resource Assessment
> > kenboss at dilbert.dnr.state.mn.us Minnesota Dept. of Natural
> > Resources
> > Voice: 218 327 4449 ext. 237 413 SE 13th Street
> > Fax: 218 327 4517 Grand Rapids, MN 55744
> > USA
> > www.ra.dnr.state.mn.us
> > > Yes, but what about the world file(.twf)?
> > > - John
> > > From: Stephen Woodbridge [mailto:woodbri at mediaone.net]
> > > Sent: Thursday, October 18, 2001 4:21 PM
> > > To: Arthur, John
> > > Cc: Mapserver-Users at Lists. Gis. Umn. Edu (E-mail)
> TopoZone
> > > I believe you could do that with ImageMagick and Perl to automate
> it.
> > > You should be able to chop up each of your large maps into n x m
> > tiles.
> > > -Stephen Woodbridge
> > > http://web-maps.org
> > > "Arthur, John" wrote:
> > > > I would like to use topo quads in my MapServer, but it would take
> > forever
> > > to
> > > > export each quad from Delorme's 3D topoquads. So I exported large
> > 150 mb
> > > > files instead. Is there a way to split these up into smaller
> files
> > or
> > > just
> > > > to display the large tiff in MapServer faster. We would like
> > something
> > > like
> > > > what TopoZone.com has (Mad props to you guys @ TopoZone.com), but
> > layer
> > > our
> > > > own data on top.
> > > > John Arthur
> > > > RF Technician
> > > > Office: (757) 490-7221
> > > > Cellular: (757) 692-1515
> > > > Email: john.arthur at voicestream.com
> > > > _~-^-~_
> > > > VoiceStream
> > > > W I R E L E S S
> Allan Doyle http://www.intl-interfaces.com
Cameron Shorter Web Mapping Manager
Social Change Online
248 Johnson St Tel: +61 (0) 2 9692 5115
Annandale NSW 2038 Fax: +61 (0) 2 9692 5192
Sydney, Australia http://webmap.socialchange.net.au
