[mapserver-users] Runaway process and other wierdness
Bruno Gendron
bruno_gendron at yahoo.com
Mon Oct 29 10:06:47 EST 2001
Bonjour Daniel,
I confirm that I get my errors with PHP as an Apache
module (php4.0.4pl1) on Apache Advanced Extranet
Server/1.3.19 (Linux-Mandrake)...
I will keep you informed with my experiments,
particularly on the unique filename issue!
Thanks,
Bruno
--- Daniel Morissette <morissette at dmsolutions.ca> a
écrit : > Tim, Bruno,
> I also encountered similar runaway process problems
> with the Perl
> MapScript recently but never found the root of the
> problem. Since you
> guys also get this with PHP, then I would I suspect
> that MapServer (the
> core) may do something that confuses multithread
> environments (Perl or
> PHP modules)... but that's just a guess... I'm
> really not sure about
> that.
> I've filed a bug about this in bugzilla and we
> should continue the
> discussion and investigation of this bug there:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=66
> About the random map/scalebar problem, it may well
> be a different issue,
> either related to the way the "maybe-not-so-unique"
> image filenames are
> built by the PHP module, to something being done
> wrong in the PHP
> module, or to some static variables (???) somewhere
> in MapServer that
> would screw things up in multithread environments.
> So I filed this as a
> separate bug, and the same way we should continue
> the
> discussion/investigation there:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=67
> Bruno, can you please confirm that you get this with
> PHP4 as an apache
> module?
> I'll see if I can reproduce the problems here, but
> if you can provide
> sample scripts that reproduce them then that would
> help a lot.
> Daniel Morissette
> DM Solutions Group
> http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today,
> because if
> you enjoy it today you can do it again
> tomorrow.
___________________________________________________________
Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
Yahoo! Courrier : http://courrier.yahoo.fr
