[mapserver-users] Itemquery in Mapscript(PHP)
Laurent FOULONNEAU
adsllaurentf at canl.nc
Sat Sep 1 01:00:40 EDT 2001
John,
Is this the only layer in your mapfile ? if yes it must show nothing at the
first time.
Have you tried a regex expression like /./ does it show somethig ? It show
all in my case...
I ve tested and it work fine for me with OGR but in this case I have to
protect non regex $value with " "
eg :
$class->setExpression($value); --> $class->setExpression("\"$value\"");
or directly in the search text box .
What is strange is that it did not zoom to the object ??? why ?
Your error look like more a problem with your mapinfo tables. Are you sure
that your VA_CNTY.dat (for the data) exist and is not corrupted. I check my
mapinfo files with mapinfo proviewer before using them in mapserver.
My BDF.* mapinfo files comme from mapinfo 4.5 with a column named ID
My layer in map file for OGR and mapinfo file is :
LAYER
NAME BDF
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "D:\Program Files\Apache
Group\Apache\htdocs\dev\montdore\BDF.tab"
CLASSITEM "ID"
CLASS
NAME "ID"
END
END # layer
Bon courage
Laurent FOULONNEAU
----- Original Message -----
From: "Arthur, John" <John.Arthur at voicestream.com>
To: "'Laurent FOULONNEAU'" <adsllaurentf at canl.nc>;
<mapserver-users at lists.gis.umn.edu>
Sent: Friday, August 31, 2001 12:44 AM
Subject: RE: [mapserver-users] Itemquery in Mapscript(PHP)
> Laurent,
> Thanks for your help. I must be doing something wrong, it didn't seem to
> work for me. I'm using 3.5
> When I run the search the first time, the map is returned, but nothing is
> highlighted or zoomed.
> When I run the search the second time, an error is returned:
> Warning: MapServer Error in msLoadMap(): ():(0) in c:\program
> files\apache group\apache\mapinfo\htdocs\drawquery.php on line 7
> My layer is as follows:
> LAYER
> NAME countysearch
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "c:/mapinfo work files/VA/Counties/VA_CNTY.tab"
> CLASSITEM "County"
> CLASS
> NAME "County"
> END
> END # layer
> My form is as follows:
> <FORM>
> <input type="hidden" name="mode" value="itemquery">
> <input type="hidden" name="item" value="County">
> <input type="hidden" name="qlayer" value="countysearch">
> <input type="TEXT" size="30" name="value" value="">
> <input type="submit" value="Search">
> </FORM>
> Does this not work with OGR?
> Thanks
> John Arthur
> -----Original Message-----
> From: Laurent FOULONNEAU [mailto:adsllaurentf at canl.nc]
> Sent: Thursday, August 30, 2001 7:48 AM
> To: Arthur, John; mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] Itemquery in Mapscript(PHP)
> Could certainly be improved.....
> First you have a blank image, when you use the search form, your object is
> 'automagically' ;) zoomed and painted in red
> The others object are not showed.
> Laurent
> //--------------------------------------begin draw_query.php
> <HTML>
> <?php
> dl("php_mapscript.dll"); // PHP4
> // variables globales
> $map_obj= ms_newMapObj("yourmapfile.map");
> $red = $map_obj->addColor(255, 0, 0);
> // fonctions
> function DrawQueryMap()
> GLOBAL $map_obj,$mode,$item, $qlayer, $value,$red;
> if($qlayer && $mode == "itemquery" && $value && $item)
> $layer = $map_obj->getlayerbyname($qlayer);
> for ($c=0; $c < $layer->numclasses; $c++)
> $class=$layer->getclass($c);
> if ($class->name == $item)
> $class->set("color", $red);
> $img = $map_obj->draw();
> $url = $img->saveWebImage($img, 0, 0, -1);
> echo"<INPUT TYPE=image SRC=$url BORDER=0 WIDTH=$map_obj->width
> HEIGHT=$map_obj->height NAME=mainmap>";
> <HEAD>
> <?php DrawQueryMap() ?>
> </HEAD>
> <FORM>
> value="your_class_name_in_the_map_file">
> value="your_layer_in_the_map_file">
> </FORM>
> </HTML>
> //------------------------------------- end of draw_query.php
> //-----------------------------yourmapfile.map : add a layer with a class
> name and a classitem with the same name
> LAYER
> NAME your_layer_in_the_map_file
> TYPE POLYGON
> STATUS ON
> DATA your_shape_file
> CLASSITEM "your_class_name_in_the_map_file"
> CLASS
> NAME "your_class_name_in_the_map_file"
> END
> END # layer
> //----------------end of layer definition
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, August 30, 2001 7:10 AM
> Subject: [mapserver-users] Itemquery in Mapscript(PHP)
> > Sorry if this is documented somewhere, but I couldn't find anything on
how
> > to perform an Itemquery in PHP mapscript(not cgi).
> > I would like to type a search on a field (in a point or polygon layer)
and
> > return a map zoomed in on that search.
> > John Arthur
> > RF Technician
> > Office: (757) 490-7221
> > Cellular: (757) 692-1515
> > Email: john.arthur at voicestream.com
> > _~-^-~_
> > VoiceStream
> > W I R E L E S S
