[mapserver-users] mapxy + scale / buffer not work!
Michael Achtzehn
M.Achtzehn at cui.de
Wed Sep 5 10:53:50 EDT 2001
Hallo,
An apparent old problem, for which I could not discover a solution in the Mailing.
I would like to determine an object with one ID (here regnrba) ) from a data base to display.
With ITEMQUERY mode and using MAPXY=SHAPE I would like to show the result on certain scale, but BUFFER or SCALE parameter does nothing.
Where are the contents of the variable shapes defined - is ' shapes " a variable or a keyword for the map server? Do I have to make 'shapes' special entries for the
definition of in templete file?
Where is the mistake - how can I solve my problem?
(I work with mapserver 3.4 on Win NT.)
my data:
URL: http://ms_test.cui.de/cgi-bin/mapserv.exe?map=ms_demo/isab02.map&layer=lsa_tfb&mode=itemquery&item=regnrba&value=1105-41/15&mapxy=shapes;scale=50000
mapfile:
map
extent 4401328.5 5644860.0 4582087.0 5878911.5
imagecolor 255 255 255
name "isab02"
shapepath "data"
size 600 600
status on
symbolset "symbols/all.sym"
#MA fontset eingefügt für Beschriftung der Lables
fontset "font.set"
units meters
# 1 web isab01.html
web
footer "isab02_footer.html"
header "isab02_header.html"
imagepath "C:/Inetpub/wwwroot/ms_demo/tmp/"
imageurl "/ms_demo/tmp/"
template "isab02.html"
end
# 2 querymap hilite
querymap
STATUS ON
STYLE HILITE
COLOR 255 255 0
size 700 500
end
# 3 scalebar #none
scalebar
backgroundcolor 255 255 0
color 255 255 255
intervals 4
outlinecolor 0 0 0
size 200 7
status on
style 0
transparent true
units meters
# 1 label #none
label
backgroundcolor 0 0 0
color 255 255 0
size tiny
end
end
# 4 layer lsarb
layer
classitem "MERGE_RP"
data "lsarb"
# group "lsarb"
labelcache on
labelitem "MERGE_RP"
name "lsarb"
# postlabelcache true # Wenn Option aktiv erscheint Fläche immer oben
queryitem "MERGE_RP"
status on
type polygon
# 2 class {RP Dessau}
class
color 255 217 125
SYMBOL 2
expression "151"
name "RP Dessau"
outlinecolor 0 0 0
label
color 0 128 255
end # label
end
# 3 class {RP Halle}
class
color 255 251 195
expression "152"
name "RP Halle"
outlinecolor 0 0 0
label
color 0 128 255
end # label
end
# 4 class {RP Magdeburg}
class
color 183 223 134
expression "153"
name "RP Magdeburg"
outlinecolor 0 0 0
label
color 0 128 255
end # label
end
end
# 5 layer lsa_tfb
layer
name "lsa_tfb"
type polygon
status on
data "lsa_tfb"
header "lsa_tfb_header.html"
# 1 query #none
query
template "lsa_tfb_query.html"
end
minscale 10000
labelcache on
labelitem "REGNR_BA"
# postlabelcache true # wenn Option aktiv, kein Hiliting in der Abfrage!
# 2 class lsa_tfb_1
class
name "Tiefbauflaechen"
SYMBOL 0
color 230 221 251
outlinecolor 0 0 0
# 1 label #none
label
angle auto
antialias
backgroundcolor 250 250 150
buffer 2 #Größe des Labels (MA)
color 140 70 5
font "arial"
maxsize 12
minsize 7
position cr
size small
type truetype
end # label
end
end
# 6 reference graphics/reference.gif
reference
color -1 -1 -1
image "graphics/reference.gif"
outlinecolor 255 0 0
size 120 120
status on
end
# 8 legend #none
legend
keysize 18 12
status on
# 1 label #none
label
color 0 0 89
size medium
type bitmap
end
end
end
_
query_templet:
<font size="+1" face="arial,helvetica"><b>
<html>
<head>
<title></title>
</head>
<body>
<p>Informationssystem Altbergbau</b></font> </p>
<table cellpadding="3" cellspacing="0" border="0">
<tr>
<td><img border="2" src="[img]"></td>
<!-- in dieser Variante nicht verwendet
<td><img border="2"
src="/cgi-bin/mapserv.exe?map=[map]&queryfile=C:\Inetpub\wwwroot\ms_demo/tmp/isab01[id].qy[get_layers]&mode=map&size=600+600"></td>
</tr>
<tr>
<th align="center">Abfrageergebnis</th>
<th align="center">cached query</th>
</tr>
</table>
</body>
</html>
Thank you
Michael Achtzehn
Dipl.-Ing. M. Achtzehn
CUI - Consultinggesellschaft für Umwelt und Infrastruktur
Eisenbahnstraße 10
06132 Halle
____________________
www.cui.de
Tel.: 0345 7742 749
Fax.: 0345 7742 754
