[mapserver-users] Putting a point on my map
Jim Burnett
jimburnett at ntelos.net
Wed Sep 12 09:18:05 EDT 2001
I only know the extents, I want to put a point over a shape, in my map,
based on my search.
May have multiple points. Basically I want to use the expression setting in
the layer object to show points or icons.
-jim
----- Original Message -----
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
To: <mapserver-users at lists.gis.umn.edu>; <jimburnett at ntelos.net>
Sent: Wednesday, September 05, 2001 5:10 PM
Subject: Re: [mapserver-users] Putting a point on my map
> Assuming you've working within a layer that has already been defined
> or read from a mapfile, and that the coordinates reside in a pointObj then
> you use the draw method.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Jim Burnett <jimburnett at ntelos.net> 09/05/01 09:43AM >>>
> OK, could someone point me in the right direction as to wich function in
> MapScript I would use to get a point to show up on parcels? So if I do a
> search on my data, it would put dots, or push pins on the parcels. I can
get
> the extents of those parcels, but what function do I use to put a Dot or
Pin
> at those extents?
> thanks!
> -jim
