[mapserver-users] Putting a point on my map
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Sep 5 17:10:54 EDT 2001
Assuming you've working within a layer that has already been defined
or read from a mapfile, and that the coordinates reside in a pointObj then
you use the draw method.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Jim Burnett <jimburnett at ntelos.net> 09/05/01 09:43AM >>>
OK, could someone point me in the right direction as to wich function in
MapScript I would use to get a point to show up on parcels? So if I do a
search on my data, it would put dots, or push pins on the parcels. I can get
the extents of those parcels, but what function do I use to put a Dot or Pin
at those extents?
thanks!
-jim
