[mapserver-users] adding labels via php mapscript
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Sep 5 18:50:41 EDT 2001
Assuming your allowing for cached labels you need to call the drawLabelCache method once your done with all drawing (and before outputing the image of course). This applies to all layer types. Unless specificly disabled drawing of the cache takes place post feature rendering. The mapObj draw method takes care of this for you but in this case you must manually call it.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "A. Giacomelli" <andreag at crs4.it> 09/05/01 12:35 PM >>>
I'm talking about adding labels/annotation dynamically via a
ms_point->draw method.
I know this has already been discussed on the list, and I have the
postings from the archives, but it's not getting to work.
I would appreciate if you could check the code snippets included.
There was also a similar posting a couple of weeks ago, but I think it
is not related to the same version of mapserv, and was referring to
polygons, rather than points, so I would like to double check...
I am currently working on 3.4 + php4.
TIA for any suggestions,
Here goes the code. It's supposed to write MYSTRING in the middle of my
image.
PHPmapscript part:
$mylayer = $gpoMap->getLayerByName("credits");
$txtp = ms_newpointobj();
$txtp->setXY( $myMap->extent->miny + ($gpoMap->extent->max -
$gpoMap->extent->minx)/2 , $gpoMap->extent->miny + ($gpoMap->ex
tent->maxy -$gpoMap->extent->miny )/2);
//$txtp->draw($myMap,$mylayer,$img,"credits","MYSTRING");
$txtp->draw($myMap,$mylayer,$img,0,"MYSTRING");
MAP file
LAYER
NAME credits
TYPE POINT # TRIED ALSO W/ ANNOTATION
STATUS ON
CLASS
NAME credits
COLOR 0 0 255
LABEL
COLOR 0 0 255
FORCE TRUE
TYPE TRUETYPE
FONT fritqat-italic
MINSIZE 15
MAXSIZE 30
END
END
END
Andrea Giacomelli
Centre for Advanced Studies, Research and
Development in Sardinia
http://www.crs4.it/~andreag
