[mapserver-users] Polygon symbols
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Sep 7 18:03:59 EDT 2001
Stephan: Sure, lot's of them. Here's a sample hashed one:
SYMBOL
NAME 'hash'
TYPE VECTOR
POINTS
0 0
1 1
END
END
The POINTS section defines a line going from 0,0 to 1,1 on the unit
square (sorta like this - /). That line is turned into a simple brush and
is used to fill the polygon. You can also create images outside of MapServer
to do the same thing.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Stephan Dunning <SDunning at nephrology.org> 09/07/01 11:26AM >>>
Are there symbols available to "shade" a polygon with something like
diagonal lines or interspersed dots instead of actual color shades?
If not, is it possible to create some and add them to the symbol file?
Thanks,
Stephan
