[mapserver-users] php queryByPoint
Daniel Morissette
morissette at dmsolutions.ca
Sat Sep 8 11:12:50 EDT 2001
> Aaron Hunt wrote:
> I am trying to use php mapscript to query a map file using
> queryByPoint and all I ever get is
> "Warning: MapServer Error in msQueryByPoint(): No matching record(s)
> found. "
> Can anyone help me, or direct me to some examples, with querying and
> displaying the results.
Your code seems to do the right thing... I would suggest that you check
the following:
1- Did you set a TEMPLATE parameter in the queryable layer(s) or in
their CLASSes?
2- Is there really something at the location ($lat, $lon) that you are
querying? Is your data in lat/lon as well? (i.e. the query coordinates
have to be in the same projection as the map itself). Try a
queryByRect() with the whole view extent and see if that returns
something.
3- Have you tried increasing the TOLERANCE value?
Finally, the GMap PHP demo contains example of querying and displaying
results:
http://www2.dmsolutions.ca/mapserver/dl/gmap-ms35-20010726.tar.gz
The querying happens at the end of GMap75CheckClick(), around line 500
in gmap75.php3, and displaying the results is all handled in the
function GMapDumpqueryResults() which is in the same file.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
