[mapserver-users] Compiling nightly build
Ballard,Lowell
LBallard at YesVirginia.org
Mon Sep 10 17:54:46 EDT 2001
I'm not in front of a Linux box right now but try:
putting the lib directory in /etc/ld.so.conf then running /sbin/ldconfig
I think those are the commands. You can also try telling the webserver
where the library is by adding a line in httpd.conf that's something like:
LD_LIBRARY_PATH = /path/to/lib
restart the webserver.
might want to verify syntax.
-----Original Message-----
To: MapServer_Users
Sent: 9/10/01 4:20 PM
Subject: [mapserver-users] Compiling nightly build
HELP!
I'm getting very frustrated with myself trying to
compile a recent nightly build of mapserver. I have a
fresh install of Mandrake 8.0 and want to get
mapserver working. I downloaded and installed gd,
libtiff, libpng, libjpeg, etc. I also install the
ArcSDE8.1 client. The configure script runs fine with
the following arguments:
./configure --with-sde=/usr/local/arcsde/sdeexe81
--with-sde-version=81 --with-gd=../gd-1.8.4
Then I run make and everything seems to build OK.
However, when I try to run mapserv with:
./mapserv /path-to-test-map/test.map
I get:
./mapserv: error while loading shared libraries:
libpng.so.3: cannot load shared object file: No such
file or directory
The libpng.so.3 exists in /usr/local/lib and the png
tests worked ok.
Help, please...
Sorry if this sounds like a newbie question, but I'm
stuck!
Thanks,
Robert Aldridge
__________________________________________________
Do You Yahoo!?
Get email alerts & NEW webcam video instant messaging with Yahoo!
Messenger
http://im.yahoo.com
