[mapserver-users] Compiling nightly build
Daniel Morissette
morissette at dmsolutions.ca
Mon Sep 10 17:16:24 EDT 2001
Robert,
I'm not sure about Mandrake, I'm more familiar with RedHat, but they
should work the same way... 2 things to check:
1- Make sure /usr/local/bin is listed in /etc/ld.so.conf ... if it's not
there then add it
2- Rerun /sbin/ldconfig as root... this will update the runtime libpath
cache and force the system to see the latest libs that you installed.
Hope that helps,
Daniel
Robert Aldridge wrote:
> HELP!
> I'm getting very frustrated with myself trying to
> compile a recent nightly build of mapserver. I have a
> fresh install of Mandrake 8.0 and want to get
> mapserver working. I downloaded and installed gd,
> libtiff, libpng, libjpeg, etc. I also install the
> ArcSDE8.1 client. The configure script runs fine with
> the following arguments:
> ./configure --with-sde=/usr/local/arcsde/sdeexe81
> --with-sde-version=81 --with-gd=../gd-1.8.4
> Then I run make and everything seems to build OK.
> However, when I try to run mapserv with:
> ./mapserv /path-to-test-map/test.map
> I get:
> ./mapserv: error while loading shared libraries:
> libpng.so.3: cannot load shared object file: No such
> file or directory
> The libpng.so.3 exists in /usr/local/lib and the png
> tests worked ok.
> Help, please...
> Sorry if this sounds like a newbie question, but I'm
> stuck!
> Thanks,
> Robert Aldridge
> __________________________________________________
> Do You Yahoo!?
> Get email alerts & NEW webcam video instant messaging with Yahoo! Messenger
> http://im.yahoo.com
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
