[mapserver-users] QueryByPoint
ANDREW WOOLEY
AWOOLEY at mountainland.org
Tue Sep 18 18:27:32 EDT 2001
Folks,
I apologize if this has been asked before, but I can't seem to find any thing about it on the archives.
For some of my themes, the query works just fine. However, for others, it doesn't work at all. I have tried many different things to get it to work, but I can't understand the problem. I have copied the mapfile layer definitions for one that works and just change the data pointer and it won't work. I have tried lots of combinations and I have discovered that - for one theme - if I click on very large polygons, it works, but anything very small will not work. The same holds true with lines - larger lines work - smaller ones don't. Does this make any sense to anyone? I just can't figure it out. I have adjusted my tolerance from 1 to 1000 and many places in between, but no avail.
Any suggestions would be appreciated.
Andrew
