[mapserver-users] Newbie, misplacing raster images with
phpmapscript.
Daniel Morissette
morissette at dmsolutions.ca
Wed Sep 26 10:05:47 EDT 2001
Bart,
Seems like a GD1.2 vs GD 1.3+ issue again. Can you make sure that your
PHP is NOT compiled with GD... or if you need GD in your PHP then make
sure both MapScript and PHP are using the same GD.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
> Bart van Heijningen wrote:
> Hello Mapscript/server community,
> I experienced the following problem:
> In a nutshell:
> When I draw a map with the Mapserver I get a raster image perfectly
> placed on the other shapes.
> When drawing the map using php mapscript the raster image seems to be
> mirrored, upside down and offset quite a bit compared to the first
> result.
> I use the same .map file so I do not believe that the problem should
> be looked for in there..
> Has anyone experienced this problem as well?
> Any ideas what can be the origin of this problem?
> RH 7.0
> Mapscript 35
> Mapserver 35
> php 3.0.18
> gd 1.2
> Thank you all for your time,
> Bart
