[mapserver-users] Mapserver and mapscript APIS for color changing
    Lowell.Filak
    lfilak at medinaco.org
    Tue Apr  2 05:28:30 PST 2002
The following two links may help give you an idea of how to do this:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0008/threads.html#00102
http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0108/msg00057
.html
I'm sure there are more links for that subject as it seems to come up
from time to time.
Lowell F.
On Tue, 2 Apr 2002, Alexander   Shostko wrote:
> Dear Mapserver Users !
> I need to change the colors dynamically for certain polygins
> and/or for layers (depends on how the image is composed). The
> mapfile provides color definition, but I would like to change
> it based on some time-dependent process.
> I plan to invoke the function (integrated into mapserver after
> processing the map file) or using mapscript.
> If anyone can suggest the APIs to use for
> -> layers color setting
> -> individual polygon color setting (based on the attributes in
> *.dbf file)
> I will very much appreciate it.
> Thanks in advance,
> Alexander Shostko
> shostko at ureach.com
More information about the MapServer-users
