[mapserver-users] change image size for REAL
Scott D Cogan
cogansco at msu.edu
Tue Apr 2 13:06:18 EST 2002
i am trying to change the image size that gets drawn with mapscript using
the $image=$map->draw() function.
i change the dimensions before drawing each time:
$map->width=400;
$map->height=400;
and i have changed the dimensions of the image in the HTML code.
this works, but the problem is that it doesnt REALLY change the output size
of the actual GIF image i am using. all that happens is that the 600x600
image gets scaled down to whatever size i told it to. this is unacceptable
because in scaling down, many border lines are lost and the image is
confusing. any ideas?
-scott
