[mapserver-users] [Fwd: getFeatureInfo]
Daniel Morissette
morissette at dmsolutions.ca
Tue Apr 2 10:07:54 EST 2002
Hi Doug,
Doug Nebert wrote:
> How do I set up a getFeatureInfo on a mapserver layer? I looked
> on the website but did not see the particular example for this.
Do you mean making a layer queryable via GetFeatureInfo WMS requests?
Simply setting a query template in your layer definition in the mapfile
makes it queryable in the WMS Capabilities, and then you can use it in a
GetFeatureInfo request.
GetFeatureInfo supports up to three INFO_FORMATs in the latest version
of MapServer depending on your configuration:
- INFO_FORMAT=text/plain - List feature ids and attibute names value in
plain text format
- INFO_FORMAT=application/vnd.ogc.gml - returns selected features in
GML format. You also have to set "DUMP TRUE" in your layer to enable
this.
- INFO_FORMAT=text/html - Uses the MapServer query template to produce
query results in HTML format. Works exactly like the traditional
mapserv CGI query templates.
> Also, is there a way to slave the "STYLE" request in a WMS getMap
> request to go to one or another mapfile section? For example, I
> have set up a current conditions weather data server with both
> a WMS and WFS interface. Since it has many hourly parameters,
> I'd like to expose many possibilities to label. One convenient
> way to do this might be have one weather layer and have STYLEs
> for each parameter that would set the label item or symbol
> differently, requiring different mapfile blocks.
> Thus one could display temperature, dewpoint, wind direction,
> etc as "styles" of weather display. Is this possible, or must
> I treat these as distinct layers?
SLD and STYLEs are not supported by the current version. If I properly
understood what you're trying to do, then it would seem that defining
separate layers would be your best option for now.
Best Regards,
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
