[mapserver-users] Help with compiling on Windows?
Assefa Yewondwossen
assefa at dmsolutions.ca
Tue Apr 2 13:28:41 EST 2002
Hi There,
If you only need the binarries, the mapserver site provides windows binaries
with the WMS server and client support :
http://mapserver.gis.umn.edu/win32bin/ms35gif_gdal_wms.zip
Later,
Frank Nelson wrote:
> Hello,
> I'm new to MapServer and at this point I'm still evaluating it. So far I'm
> very impressed. However, one of the key items I need to evaluate is its WMS
> Client capabilities. I'm currently using the binaries on Windows 2000 that
> I downloaded from the homepage. Per the instructions, I executed "mapserv
> -v" to check out what capabilites it was compiled with. WMS Server is in
> there, but not WMS Client. So I thought, no big deal, I'll just recompile
> it and turn on WMS Client. I didn't know what I was getting myself into!!!
> I'm not a C programmer. I've followed instructions, searched mailing list
> archives and 3 days later I don't feel like I'm getting any closer. It
> seems that compiling MapServer itself is straight forward as there is
> documentation and a VC++ makefile. However it is all the supporting
> libraries that I'm having problems with... and it looks like the regex
> library wasn't even meant to compile on windows. I think it would've been
> very helpful if, whoever compiled those binares for windows, also made
> available the source that was compiled.. even without documenation. Then I
> could learn by looking at the changes that were made in order to compile on
> Windows.
> I need all the help I can get but I don't expect anyone to spend tremendous
> amounts of time with me. So maybe, at a minimum I could get someone who has
> successfully compiled version 3.5 on Windows to jot down a few clues. Some
> sample questions I have are..
> My understanding is that I need to get ZLib, FreeType and LibPNG copmiled
> first. Then those three will be used to in the GD compiling process. Then
> all of the above will be used in the MapServer compiling process.... am I on
> the right track?
> Regardless, I can't get anything other than PROJ4 to compile. For those
> libraries that don't have a Makefile.vc that I can't use VC++ on, what do I
> use to compile? I downloaded a gcc compiler that has the "make" command,
> but that doesn't seem to work on any of the makefiles and gcc compiles .c
> files into .exe's when I really need .lib's...
> I think I could get MapServer compiled if I could just get all these
> supporting libraries how they need to be.
> I don't expect anyone to answer ALL my question, but any little bit of
> information would be GREATLY appreciated!!
> _________________________________________________________________
> Chat with friends online, try MSN Messenger: http://messenger.msn.com
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056
Fax: (613) 565-0925
