[mapserver-users] how come drawMap works?
Puneet Kishor
pkishor at GeoAnalytics.com
Tue Apr 2 17:40:16 EST 2002
Steve,
You could well be right, except in my case it was simply a case of my right
brain not knowing what my left finger was doing. I had written a function
and forgotten all about it, and was inadvertently calling it.
Essentially, I got lost in my own code, and hence it was all my fault.
That said, you may well be right about the bug you note below. I will check
my server and see what all I've got.
Thanks,
pk/
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Tuesday, April 02, 2002 4:37 PM
> To: Puneet Kishor
> Cc: 'Daniel Morissette'; MapServer-list
> Subject: Re: [mapserver-users] how come drawMap works?
> I think I have an idea about this. There is a serious bug in the build
> environment - when you build mapscript it does NOT link with the just
> built libmap.a!!!! It links with the installed version of
> libmap.a if it
> exists! The Makefile(s) for mapscript need to explicitly load
> ../..libmap.a so insure that the correct one is loaded.
> Puneet, see if you have a /usr/lib/libmap.a or /usr/local/lib/libmap.a
> and delete it then make clean; make and you will probably get
> the error.
> Could somebody chnage the Makefile(s). I will add this to bugzilla.
> -Steve Woodbridge
> Puneet Kishor wrote:
> > dunno man... no error at all... it happily draws the map
> for me. go figure.
> > pk/
> > > From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> > > Sent: Tuesday, April 02, 2002 11:03 AM
> > > To: Puneet Kishor
> > > Cc: MapServer-list
> > > > I quite accidentally had been using drawMap() for rendering
> > > my map, until I
> > > > discovered that was not a part of PHP/Mapscript 3.5
> > > anymore. So, how the
> > > > heck does it still work? Did you folks leave it in there for
> > > > backward-compatibility?
> > > drawMap() is not there at all in PHP/Mapscript 3.5 ... you
> > > should get an
> > > error about this in your HTML source (do a "View Source" in your
> > > browser).
> > > Daniel Morissette morissette at dmsolutions.ca
> > > DM Solutions Group http://www.dmsolutions.ca/
> > > Don't put for tomorrow what you can do today, because if
> > > you enjoy it today you can do it again tomorrow.
