[mapserver-users] attributes from *.dbf file
Stepan Kafka
stepan.kafka at centrum.cz
Wed Apr 3 02:14:18 EST 2002
The states must be quoted in the expression, e.g.:
EXPRESSION ("[STATE]" = "Alaska" and [LEVEL] > 3 and [LEVEL] < 6 )
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]za uivatele Alexander
> Shostko
> Odesláno: 3. dubna 2002 7:17
> Komu: mapserver-users at lists.gis.umn.edu
> Pøedmìt: [mapserver-users] attributes from *.dbf file
> Dear mapserver users!
> Thanks in advance for the help!
> If there are a attributes defined for each shape in *.dbf file,
> let's say STATE and LEVEL. State is a string and level is an
> integer. I need to use it from the map file to set the color.
> Is it sufficient to use the expression , for ezample:
> CLASS
> EXPRESSION ([STATE] = “Alaska” and [LEVEL] > 3 and
> [LEVEL] <
> 6 )
> COLOR 255 0 0
> END
> CLASS
> EXPRESSION ([STATE] = “Virginia” and [LEVEL] > 6
> and [LEVEL]
> < 9 )
> COLOR 0 255 0
> END
> Well, I tried , it does not do anything. But even if it does,
> does it set the color for each shape in the layer? (Not sure)
> Thanks a lot
> Alexander Shostko
> shostko at ureach.com
