[mapserver-users] msSearchDiskTree(): Errors
Ranga Raju Vatsavai
vatsavai at cs.umn.edu
Wed Apr 3 12:40:07 EST 2002
I unsubscribed this user from the list, hope these duplicates will
die in a couple of days.
Thanks,
Raju
[ Charset ISO-8859-1 unsupported, converting... ]
> i remember seeing this a few days ago! this is also from taiwan.com...
> > -----Original Message-----
> > From: Sean Gillies [mailto:sgillies at i3.com]
> > Sent: Saturday, March 30, 2002 12:48 PM
> > To: MapServer List
> > Subject: Re: [mapserver-users] msSearchDiskTree(): Errors
> > Stephen,
> > I had the same symptoms when I first started using Python MapScript
> > on Win32.
> > A shapefile that was working for me with the Mapserv program was
> > not accessible through the mapObj.draw() method.
> > After pulling out half my hair I tried a different shape file and
> > had no problems.
> > The difference between my shapefiles is that the accessible file
> > was generated from ArcView and the inaccessible file was produced
> > by PCI Geomatics software. I'm not certain why MapScript would
> > have higher standards for shapefiles than Mapserv (or ArcView).
> > Sorry that I don't have an answer for your problem, but maybe you
> > can use my experience.
> > cheers,
> > Sean
> > Stephen Woodbridge wrote:
> > > Chris et al,
> > > Thanks,this is good to know,
> > > but I don't think this is the case with the data set I just
> > built. And
> > > if it is the case with this dataset, then I need to know what is the
> > > problem so I can fix it. I just built the tileindexes based on the
> > > exitance of the shp files. So I don't know how there can be missing
> > > data.
> > > If there is missing data then,
> > > HOW do I figure out what files are missing?
> > > Mapserver is clearly complaining about something, but the
> > error message
> > > is not adequate to figure out the problem.
> > > imap at chesapeake.net wrote:
> > >>Steve,
> > >>I dont think these are errors... this occurs when you are missing
> > >>files in your tiles. (ie. county tile missing a feature layer)
> > >>They occur in the MS_ERRORLOG, but dont effect processing
> > >>unless you have not defined IGNORE_MISSING_DATA at compile time.
> > >>This has been in the code for a long time...
> > >>There should probably be some logic coded into the source to
> > >>get rid of these messages if IGNORE_MISSING_DATA is defined. It
> > >>tends to fill up the logfile.
> > >>-Chris Stuber (mapsurfer)
> > >>>Hi all,
> > >>>I searched the archives, but could not find anything useful on this
> > >>>error message:
> > >>>Sat Mar 30 12:31:35 2002 - msSearchDiskTree(): Unable to
> > access file.
> > >>>I have a bunch of tileindexes referenced in my mapfile, I
> > have checked
> > >>>all the files and directories to make sure they are
> > accessible. I turned
> > >>>on error logging to a file but got nothing more useful
> > than what was get
> > >>>prionted in the scripts.
> > >>>How do I find out what file msSearchDiskTree() is
> > complaining about?
> > >>>I am running ms_3.5 release. I tried 3/20 nightly and
> > could not get any
> > >>>thing to display. the error is alway on the php/mapscript line
> > >>>$image = $map->draw();
> > >>>I rebuilt all my tileindexes and there shptrees.
> > >>>So, I am at a total loss on how to proceed.
> > >>>Thanks again for any help or suggestions you might offer.
> > >>>-Steve
