[mapserver-users] Map Viewer for use on laptop
E Perik
erwin at perik.nu
Wed Apr 3 12:30:34 EST 2002
Regarding my first question I did get some useful answers, however ...
Is there a low budget Viewer + database-editing option available?
In general only ESRI shapefiles are used, so that should keep a lot of
options open.
The reason why I ask is because local resellers are referring to huge
program's, often based on a webserver or the viewer uses a non-standard
file-format.
So if I go out in the field (uhu uhum) with a laptop/PDA and want to
edit data of an object, what would be a simple program to use?
Setting up mapserver+apache+PHP could do this, but I was looking for
another (quicker) solution.
Any tip is more then welcome!
Erwin
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of E Perik
Sent: Thursday, March 28, 2002 11:47 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Map Viewer for use on laptop
Hi All,
I know this is totally off topic, but are there some good GIS-viewers to
view maps also used by Mapviewer on a laptop without a webserver ?
Functionality should be no more like:
* Zoom
* Pan
* Identify/Query
* Search
All data are ESRI shape-files and some GEOTIFF's.
Did some searches on the internet, but did not come up with many
results.
Now I only use ArcExplorer from ESRI, but are there other low-price
solutions available?
Thanks in advance,
Erwin
