[mapserver-users] Map Viewer for use on laptop
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 3 13:06:56 EST 2002
I'm sorry, I haven't been following this thread but why not get
ArcExplorer2 which is a free download from the ESRI site?
Granted it is view only app. As soon as you want to edit files the
problem become a little more complex. :)
-Steve
E Perik wrote:
> Regarding my first question I did get some useful answers, however ...
> Is there a low budget Viewer + database-editing option available?
> In general only ESRI shapefiles are used, so that should keep a lot of
> options open.
> The reason why I ask is because local resellers are referring to huge
> program's, often based on a webserver or the viewer uses a non-standard
> file-format.
> So if I go out in the field (uhu uhum) with a laptop/PDA and want to
> edit data of an object, what would be a simple program to use?
> Setting up mapserver+apache+PHP could do this, but I was looking for
> another (quicker) solution.
> Any tip is more then welcome!
> Erwin
> -----Original Message-----
> From: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of E Perik
> Sent: Thursday, March 28, 2002 11:47 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] Map Viewer for use on laptop
> Hi All,
> I know this is totally off topic, but are there some good GIS-viewers to
> view maps also used by Mapviewer on a laptop without a webserver ?
> Functionality should be no more like:
> * Zoom
> * Pan
> * Identify/Query
> * Search
> All data are ESRI shape-files and some GEOTIFF's.
> Did some searches on the internet, but did not come up with many
> results.
> Now I only use ArcExplorer from ESRI, but are there other low-price
> solutions available?
> Thanks in advance,
> Erwin
