[mapserver-users] RE: dynamically allocated points for MAP w/ PHP
E Perik
erwin at perik.nu
Wed Apr 3 16:25:13 EST 2002
Just found an earlier example:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0203/msg00293.html
In general the same as previous mail
-----Original Message-----
Sent: Wednesday, April 03, 2002 10:28 PM
To: Consult IT!, E. Perik; mapserver-users at lists.gis.umn.edu
Subject: dynamically allocated points for MAP w/ PHP
what is wrong with this PHP code? i am trying to create a layer of
points
using mapscript. i had this working previously, then somehow deleted
the
file. now i cant figure it out again:
if ($init==1) {
// recreate the site layer
$shpFname = "C:\\Program Files\\Apache\\htdocs\\mich\\data\\shptest";
$shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
$def = array(array("PROG_ID", "N", 5, 0));
$dbfFile = dbase_create($shpFname . ".dbf", $def);
createPoint( 14, 34, 111);
createPoint( 33, 14, 222);
createPoint( 10, 20, 333);
// done... cleanup
$shpFile->free();
dbase_close($dbfFile);
function createPoint($x, $y, $name){
GLOBAL $shpFile, $dbfFile;
// Create shape
$oShp = ms_newShapeObj(MS_SHP_POINT);
$oLine = ms_newLineObj();
$oLine->addXY($x, $y);
$oShp->add( $oLine );
$shpFile->addShape($oShp);
// Write attribute record
dbase_add_record($dbfFile, array($name));
