[mapserver-users] RE: dynamically allocated points for MAP w/
PHP
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Fri Apr 5 14:19:11 EST 2002
Erwin,
Thanks, it's working.
I just found out in a php tutorial that you have to use
<SELECT NAME="var[]" MULTIPLE>
for php code to work unlike perl.
This is a good tutorial for any one interested on more:
http://www.php.net/manual/phpfi2.php#selmul
> Pushkar,
> What does $HTTP_GET_VARS["layer"] return?
> What does the url look like when you use GET ?
> Maybe rewrite your select list to PHP, so you can 'make' a url array
> like:
> LayerArrayString = "a c"
> Would look something like:
> <select multiple name="LayerList[]" size="5">
> <OPTION value="A">A</OPTION>
> <OPTION value="B">B</OPTION>
> <OPTION value="C">C</OPTION>
> </select>
> Then you can call the LayerList-array using:
> $count=count($LayerList);
> for ($i=0; $i<$count; $i++) {
> echo $LayerList[$i];
> $LayerArrayString = $LayerArrayString . " " . $LayerList[$i];
> Erwin
> -----Original Message-----
> From: Pushkar Pradhan [mailto:pushkar at ERC.MsState.Edu]
> Sent: Friday, April 05, 2002 8:43 PM
> To: E Perik
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE: [mapserver-users] RE: dynamically allocated points for MAP
> w/ PHP
> Hi Erwin,
> I wrote code to implement some of the things you suggested. If I use GET
> I
> get all the params. like zoomsize, layers etc. in my address window of
> IE,
> but for POST these params. do not appear in the address window.
> But for both these methods when I print out the vals. of layer field I
> get
> only the last element selected.
> Here is the code I use:
> if ( isset($HTTP_GET_VARS["layer"]) ) {
> reset($HTTP_GET_VARS);
> $selectLayers = explode(" ", $HTTP_GET_VARS["layer"]);
> echo "here";
> foreach($selectLayers as $val) {
> echo "$val ";
> } // end of if loop
> same goes if I try POST.
> My html:
> <b>Select Layers to Display: </b><br>
> <select multiple name="layer" size=5>
> <option value="a">a
> <option value="b">b
> <option value="c">c
> <option value="d">d
> <option value="e">e
> <!-- comment php code for now
> <?php
> foreach($layerNames as $layerName) {
> switch($layerName) {
> case 'six_cnty':
> break;
> case '6cnty_quad':
> break;
> default:
> printf("<option value=$layerName> $layerName");
> </select>
> If anybody knows what's wrong?
> > Hi Pushkar, >
> > Just to check the obvious,....
> > 1) Does it echo the layername?
> > 2) Should you not use 'explode' for $layer when multiple are selected?
> > 3) Is the layername an existing one and not too long?
> > 4) Is the layer STATUS set to: DEFAULT or ON ?
> > 5) Is the layer set in your url like:
> > http://localhost/.../name.php?zoom=1&layer="layer1 layer2 layer3"
> > 6) You sure POST is correct? Did you check GET ?
> > Option 2) should use a string like "layer1 layer2 layer3" (see option
> 5)
> > and then you explode it using the space so you then use $layer[0] for
> > your first layer of the 'original-string-array'
> > For exploding use something like:
> > $LayerArray = explode(" ", $HTTP_GET_VARS["layer"]);
> > Then from the example above you get:
> > $LayerArray[0] would be "layer1"
> > $LayerArray[1] would be "layer2"
> > $LayerArray[2] would be "layer3"
> > Erwin
> > From: owner-mapserver-users at lists.gis.umn.edu
> > [mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Pushkar
> > Pradhan
> > Sent: Thursday, April 04, 2002 7:56 PM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: Re: [mapserver-users] RE: dynamically allocated points for
> MAP
> > w/ PHP
> > I have a related question, in php/mapscript I show the user a html
> list
> > from which he/she can select layers to add to the current view, I am
> > writing some code but it doesn't work can somebody provide me with the
> > algorithm if not the code like the one given below:
> > if ( isset($HTTP_POST_VARS["layer"]) ) {
> > echo $HTTP_POST_VARS["layer"];
> > $layer = $map->getLayerByName($HTTP_POST_VARS["layer"]);
> > $image = $map->prepareImage();
> > $layer->draw($image);
> > $image_url = $image->saveWebImage(MS_PNG,1,1,0);
> > } // end of if loop
> > The above code doesn't work it creates a blank image, moreover if one
> > selects multiple layers to display then only the last one selected is
> > chosen.
> > Thanks,
> > > Hi Scott, >
> > > There is nothing wrong with the PHP code, except it does not create
> a
> > > layer, but it creates a new shapefile ;-)
> > > So you want to create a layer, dynamicly, or .....
> > > Example of creating a layer from a shapefile:
> > > 0) Create map-object
> > > 1) Get object/points from existing-shapefile or from database
> > > 2) Put it in new-shapefile (as you did in your php-script)
> > > 3) Create dbf-file with name of new-shapefile
> > > 4) Clear new-shapefile (as you did)
> > > 5) Add new-layer to map-object (default of this layer is set to OFF)
> > > 6) Show new-layer (turn it ON)
> > > 7) Draw the map (now includes newly created shapefile ;-) )
> > > Explanation:
> > > *** In 0) you use like: $Map = ms_newMapObj("blabla.map");
> > > *** In 1) you determine input. This could be the 3 points you have
> in
> > > your example, but also could be a shape or lat/lon from a database
> > (eg.
> > > dbf/MySQL)
> > > *** Option 2) and 3) and 4) you have in your mapscript. This creates
> a
> > > shapefile + corresponding dbf-file.
> > > *** Option 5) and 6) is best done using a dummy-layer which is set
> to
> > > OFF in your map-file. You turn it on AND attach the new
> shapefile-data
> > > from by using:
> > > $Dummylayer = ms_newLayerObj($Map); // a new layerobject
> > > $Dummylayer = $Map->getLayerByName("MapLayer");
> > > $Dummylayer->set("status", 1); // Turn it on
> > > $Dummylayer->set("data", $shpFname); // Add your created
> > > data
> > > While your map-layer looks something like:
> > > LAYER
> > > NAME "MapLayer"
> > > TYPE POINT
> > > STATUS OFF
> > > CLASS
> > > SYMBOL 'circle'
> > > COLOR 0 0 0
> > > SIZE 3
> > > END
> > > END
> > > *** Option 7) is something like:
> > > $ImgMap = $Map->draw();
> > > This should do the trick.
> > > Erwin
> > > From: Scott D Cogan [mailto:cogansco at msu.edu]
> > > Sent: Wednesday, April 03, 2002 10:28 PM
> > > To: Consult IT!, E. Perik; mapserver-users at lists.gis.umn.edu
> > > Subject: dynamically allocated points for MAP w/ PHP
> > > what is wrong with this PHP code? i am trying to create a layer of
> > > points
> > > using mapscript. i had this working previously, then somehow
> deleted
> > > the
> > > file. now i cant figure it out again:
> > > if ($init==1) {
> > > // recreate the site layer
> > > $shpFname = "C:\\Program
> > Files\\Apache\\htdocs\\mich\\data\\shptest";
> > > $shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
> > > $def = array(array("PROG_ID", "N", 5, 0));
> > > $dbfFile = dbase_create($shpFname . ".dbf", $def);
> > > createPoint( 14, 34, 111);
> > > createPoint( 33, 14, 222);
> > > createPoint( 10, 20, 333);
> > > // done... cleanup
> > > $shpFile->free();
> > > dbase_close($dbfFile);
> > > function createPoint($x, $y, $name){
> > > GLOBAL $shpFile, $dbfFile;
> > > // Create shape
> > > $oShp = ms_newShapeObj(MS_SHP_POINT);
> > > $oLine = ms_newLineObj();
> > > $oLine->addXY($x, $y);
> > > $oShp->add( $oLine );
> > > $shpFile->addShape($oShp);
> > > // Write attribute record
> > > dbase_add_record($dbfFile, array($name));
> > PUSHKAR S. PRADHAN
> > Research Assistant
> > MISSISSIPPI STATE UNIVERSITY,
> > STARKVILLE, MS 39759.
> > Engineering Research Center
> > Box 9627
> > Mississippi State, MS 39762-9627
> PUSHKAR S. PRADHAN
> Research Assistant
> Box 9627
PUSHKAR S. PRADHAN
Research Assistant
Box 9627
