[mapserver-users] PROJ problems
Morten Hulden
morten at ngb.se
Fri Apr 5 05:45:22 EST 2002
If you installed proj without changing the default prefix, libproj.so goes
into /usr/local/lib
You must let your system know where to find the dynamic library
libproj.so. If you are root, it may be as simple as running ldconfig, if
the path to the directory where libproj.so lives is already defined
/etc/ld.conf.
Otherwise you can edit /etc/ld.so.conf and add the path, then run
ldconfig.
If you are not root (unlikely), the programs you run will have to rely on
the $LD_LIB_PATH environment variable to find dynamic libraries.
MHu
On Fri, 5 Apr 2002, Stephane MOREL wrote:
> I got Proj from ftp://ftp.remotesensing.org/pub/proj/proj-4.4.5.tar.gz.
> I compile it
> 1)-with --prefix=/home/mapserver_3.5/proj-4.4.5/
> ./configure
> make
> make install (ok)
> then I recompile mapserver --with-proj
> ./configure --with-proj=/home/mapserver_3.5/proj-4.4.5/
> make (ok)
> when I run ./mapserv
> ./mapserv: error while loading shared libraries : libproj.so.0: cannot
> load share object file: No such file or directory
> 2)- without --prefix :
> ./configure
> make
> make install
> Evreything is fine.
> Then I recompile mapserver with --proj
> ./configure --with-proj=/usr/local/lib/
> configure: error: couldn't find projects.h or libproj.a/libproj.so in
> /usr/local/lib/
> libproj.a and libproj.so are in this directory BUT projects.h are in
> /usr/local/include/
> What am I missing ?
> stef
> Morten Hulden a écrit :
> > Get PROJ from
> > compile and install it and then rebuild your mapserver --with-proj
> > MHu
> > On Thu, 4 Apr 2002, Stephane MOREL wrote:
> > > Hi,
> > > I ve installed mapserver 3.5 on a suse linux 7.2 with proj support.
> > > When I run ./mapserv -v i have :
> > > Mapserver version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORT=PROJ
> > > SUPPORTS=TTF SUPPORT=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> > > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE.
> > > I understand that proj support is supported.
> > > But when I put a projection clause in may mapfile I got the following
> > > message :
> > > Warning: MapServer Error in loadProjection(): Projection support is not
> > > available
> > > If someone can explain this to me or tell where I can find something
> > > about using the proj clause even with mapscript....
> > > Thanks
> > > Stef
> > > PS : excuse me for my poor english!!!!!;o))))
