[mapserver-users] No errors, but no lines on output map.
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 5 14:41:23 EST 2002
Ben,
Change your map file to :
UNITS DD
# extents for all of Virginia
EXTENT -83.682000 36.543600 -74.952000 39.769180
should fix your problem.
-Steve
Ben Logan wrote:
> Hello,
> I am just getting started with mapserver and am trying a very simple
> setup to begin with. My HTML files are modified versions of the
> Itasca demo files, and so is the map file (which I've included below).
> My data source is a single county's worth (Carroll county VA) of
> Tiger/LINE 2000 files. I compiled mapserver with projection support
> and OGR support, and the log doesn't show any errors when I run it.
> However, I don't get any lines in the output map. I also had this
> problem with a shapefile I was playing with, and think it is some sort
> of extents problem. The values for the map's extents (shown in the
> mapfile) are known to fall within the county I'm messing with.
> (Aren't Tiger/LINE files in lat/lon format? The extents I placed in
> my mapfile are in UTM/Meters.) I'm trying to generate a street map of
> the county, but I'm not sure I'm going about it in the correct way at
> all. :)
> How do I get the values I need for the map EXTENT? I was also
> wondering how to generate a reference image for the TIGER data.
> BTW, mapserv takes awhile to serve the data up when I specify layer 0
> in the CONNECTION arg, so it seems to be doing something with the
> data.
> # Start of map file
> NAME TEST
> STATUS ON
> SIZE 600 600
> #EXTENT -80 30 -81 40
> EXTENT 533455 4053115 544725 4067075
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> # you may need to change this to match your MapServer build
> #IMAGETYPE PNG
> # Projection definition, consult the PROJ.4 documentation for parameter discussion
> #PROJECTION
> # "proj=utm"
> # "ellps=GRS80"
> # "zone=15"
> # "north"
> # "no_defs"
> # OR:
> # "init=epsg:26915"
> #END
> # Start of web interface definition (including WMS enabling metadata)
> WEB
> HEADER test_header.html
> TEMPLATE test.html
> FOOTER test_footer.html
> LOG "test.log"
> MINSCALE 1
> MAXSCALE 400000
> IMAGEPATH "set in test_init.html"
> IMAGEURL "set in test_init.html"
> METADATA
> WMS_TITLE "A test map."
> WMS_ABSTRACT "This is a test."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://mach1.log.cabin/ben/mapserv_demo/test/test_init.html"
> WMS_SRS "EPSG:26915"
> END
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> # Start of reference map
> #REFERENCE
> # IMAGE 'graphics/ref.png'
> # #EXTENT -64 17 170 72
> # EXTENT 533455 4053115 544725 4067075
> # SIZE 120 120
> # STATUS ON
> # COLOR -1 -1 -1
> # OUTLINECOLOR 255 0 0
> #END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 255 0
> SIZE tiny
> END
> STYLE 1
> SIZE 80 2
> COLOR 0 0 255
> UNITS MILES
> INTERVALS 1
> TRANSPARENT TRUE
> STATUS TRUE
> END
> # Start of symbol definitions (we're only using a few)
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
> END
> # Start of layer definitions
> LAYER
> NAME "Carroll"
> TYPE LINE
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "data/carroll, 1"
> #CLASSITEM 'STATES'
> CLASS
> NAME "Carroll"
> #EXPRESSION /.*/
> OUTLINECOLOR 128 128 128
> COLOR 225 0 0
> END
> END
> END # Map File
> Thanks for your help,
> Ben
> Ben Logan: ben at wblogan dot net
> OpenPGP Key KeyID: A1ADD1F0
