[mapserver-users] multiple matches in $classObj->setexpression
Puneet Kishor
pkishor at GeoAnalytics.com
Fri Apr 5 17:41:04 EST 2002
with the following in my map file...
LAYER
NAME "parcels_highlight"
TYPE polygon
DATA parcel
STATUS off
CLASSITEM "OWNER"
CLASS
OUTLINECOLOR 255 0 0
COLOR 255 255 0
END
TEMPLATE "parcels.php"
END
The following works fine...
$str = "foo";
$classObj->setexpression("\"$str\"");
$layerObj->set("status", 1);
But I want to do the following, which, needless to say, does not work...
$str = "([GIS_KEY] in (\"foo\", \"bar\", \"baz\"))";
$classObj->setexpression("\"$str \"");
In fact, I can't even get the following to work...
$str = "([GIS_KEY] eq \"foo\")"; OR
$str = "([GIS_KEY] == \"foo\")"; OR
$str = "([GIS_KEY] eq 'foo')"; etc.
What am I missing here? And if the "in" clause is not supported (doesn't
seem to be per the docs), would I need to do the following...
$str = "(([GIS_KEY] eq \"foo\") or ([GIS_KEY] eq \"bar\") or ([GIS_KEY] eq
\"baz\"))";
Tia,
pk/
