[mapserver-users] multiple matches in $classObj->setexpression
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 5 20:07:32 EST 2002
Puneet,
You want to use a regular expression so in your mapfile you would say:
CLASSITEM "GIS_KEY"
CLASS
EXPRESSION /^foo$|^bar$|^baz$/
or in php you would say something like:
$oLayer->set("classitem", "GIS_KEY");
$oClass->setexpression("/^foo$|^bar$|^baz$/");
I haven't tested this but it should be close to this syntax. Give it a
try and let us know how it goes.
-Steve W.
Puneet Kishor wrote:
> with the following in my map file...
> LAYER
> NAME "parcels_highlight"
> TYPE polygon
> DATA parcel
> STATUS off
> CLASSITEM "OWNER"
> CLASS
> OUTLINECOLOR 255 0 0
> COLOR 255 255 0
> END
> TEMPLATE "parcels.php"
> END
> The following works fine...
> $str = "foo";
> $classObj->setexpression("\"$str\"");
> $layerObj->set("status", 1);
> But I want to do the following, which, needless to say, does not work...
> $str = "([GIS_KEY] in (\"foo\", \"bar\", \"baz\"))";
> $classObj->setexpression("\"$str \"");
> In fact, I can't even get the following to work...
> $str = "([GIS_KEY] eq \"foo\")"; OR
> $str = "([GIS_KEY] == \"foo\")"; OR
> $str = "([GIS_KEY] eq 'foo')"; etc.
> What am I missing here? And if the "in" clause is not supported (doesn't
> seem to be per the docs), would I need to do the following...
> $str = "(([GIS_KEY] eq \"foo\") or ([GIS_KEY] eq \"bar\") or ([GIS_KEY] eq
> \"baz\"))";
> Tia,
> pk/
