[mapserver-users] multiple matches in $classObj->setexpression
Puneet Kishor
pkishor at GeoAnalytics.com
Sat Apr 6 10:41:01 EST 2002
Thanks Steve for responding.
As you know, I figured out the regexp solution like you also suggested...
> $oClass->setexpression("/^foo$|^bar$|^baz$/");
actually, since I wanted a full string match of many strings, I did the
following...
$oClass->setexpression("/(foo)|(bar)|(baz)/");
it works peachy.
For now my problem is solved. However, I still can't get logical
expressions to works, not at all. I can imagine wanting to do inequality
operations such as...
$oClass->setexpression("(([CI] < 5) or ([CI] > 7) or ([CI] eq
\"Puneet\"))");
but, no success. I have tried a variety of different syntactic
constructs (including different case combinations as well, even though I
know that the attributes are all upper-case), starting with the simplest
possible ([CI] = 5) and failed.
I _am_ using PHP/Mapscript right now, but also re-writing the entire
application in Perl/Maspscript.
Why are my logical expressions failing? Is there something very obvious
that I am overlooking?
>> with the following in my map file...
>> LAYER
>> NAME "parcels_highlight"
>> TYPE polygon
>> DATA parcel
>> STATUS off
>> CLASSITEM "OWNER"
>> CLASS
>> OUTLINECOLOR 255 0 0
>> COLOR 255 255 0
>> END
>> TEMPLATE "parcels.php"
>> END
>> The following works fine...
>> $str = "foo";
>> $classObj->setexpression("\"$str\"");
>> $layerObj->set("status", 1);
>> But I want to do the following, which, needless to say, does not
>> work...
>> $str = "([GIS_KEY] in (\"foo\", \"bar\", \"baz\"))";
>> $classObj->setexpression("\"$str \"");
>> In fact, I can't even get the following to work...
>> $str = "([GIS_KEY] eq \"foo\")"; OR
>> $str = "([GIS_KEY] == \"foo\")"; OR
>> $str = "([GIS_KEY] eq 'foo')"; etc.
>> What am I missing here? And if the "in" clause is not supported
>> (doesn't
>> seem to be per the docs), would I need to do the following...
>> $str = "(([GIS_KEY] eq \"foo\") or ([GIS_KEY] eq \"bar\") or
>> ([GIS_KEY] eq
>> \"baz\"))";
>> Tia,
>> pk/
