[mapserver-users] File paths for layer data
Tyler Mitchell
TMitchell at lignum.com
Fri Apr 5 18:20:35 EST 2002
I've had a similar problem Adam, again using MapServ 3.5 on Windows 2000.
I couldn't access data on network/shared drives, only locally. It's been
a while since I tried, but I hope someone else can shed some light on it
for us. Any takers?
"Ryan, Adam"
<ARyan at co.linn.or.us> To: Tyler Mitchell <TMitchell at lignum.com>,
Sent by: mapserver-users at lists.gis.umn.edu
owner-mapserver-users at lists.g cc:
is.umn.edu Fax to:
Subject: RE: [mapserver-users] File paths for layer data
04/05/2002 01:55 PM
Thanks Tyler.
I'm running MapServer 3.5 on Windows 2000. I'm networked to a handful of
county servers including the web server that my mapserver files are on.
Adam
-----Original Message-----
From: Tyler Mitchell [mailto:TMitchell at lignum.com]
Sent: Friday, April 05, 2002 1:13 PM
To: mapserver-users at lists.gis.umn.edu
Cc: aryan at co.linn.or.us
Subject: Re: [mapserver-users] File paths for layer data
Adam, I had come across similar problems but am not sure if it was only on
the windows platform or not. What is your "setup" - are you using windows,
cygwin, unix and maybe you could tell us what version you are using.
Tyler
"Ryan, Adam"
Sent by: cc:
owner-mapserver-users at lists.g Fax to:
is.umn.edu Subject:
04/05/2002 11:29 AM
> Hi all,
> I'm new at this and on a steep learning curve but I think I'm in love
with
> MapServer. It's so fast and, for the most part, easy to use.
> One problem: I want to set 'data' for a layer object in my map file to a
> file on another drive, url, server, etc. I can't get mapserver to access
> any layer files that are outside my server directory. I have images on
> the htm template file that reference other drives and servers so it
> doesn't seem to be a rights or permissions problem.
> Any suggestions?
> Thanks,
> Adam Ryan
> Linn County GIS
> Oregon
