[mapserver-users] File paths for layer data
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 5 20:21:28 EST 2002
This could be because the web server process does not have access to the
network drives. This could be because of access rights, or it could be
because you are using a mapped drive which only exists for you as a user
after you log in. Since the web server does not log in it does not have
any mapped drives and can only access the local drives.
-Steve W.
Tyler Mitchell wrote:
> I've had a similar problem Adam, again using MapServ 3.5 on Windows 2000.
> I couldn't access data on network/shared drives, only locally. It's been
> a while since I tried, but I hope someone else can shed some light on it
> for us. Any takers?
> "Ryan, Adam"
> <ARyan at co.linn.or.us> To: Tyler Mitchell <TMitchell at lignum.com>,
> Sent by: mapserver-users at lists.gis.umn.edu
> owner-mapserver-users at lists.g cc:
> is.umn.edu Fax to:
> Subject: RE: [mapserver-users] File paths for layer data
> 04/05/2002 01:55 PM
> Thanks Tyler.
> I'm running MapServer 3.5 on Windows 2000. I'm networked to a handful of
> county servers including the web server that my mapserver files are on.
> Adam
> -----Original Message-----
> From: Tyler Mitchell [mailto:TMitchell at lignum.com]
> Sent: Friday, April 05, 2002 1:13 PM
> To: mapserver-users at lists.gis.umn.edu
> Cc: aryan at co.linn.or.us
> Subject: Re: [mapserver-users] File paths for layer data
> Adam, I had come across similar problems but am not sure if it was only on
> the windows platform or not. What is your "setup" - are you using windows,
> cygwin, unix and maybe you could tell us what version you are using.
> Tyler
> "Ryan, Adam"
> Sent by: cc:
> owner-mapserver-users at lists.g Fax to:
> is.umn.edu Subject:
> 04/05/2002 11:29 AM
> > Hi all,
> > I'm new at this and on a steep learning curve but I think I'm in love
> with
> > MapServer. It's so fast and, for the most part, easy to use.
> > One problem: I want to set 'data' for a layer object in my map file to a
> > file on another drive, url, server, etc. I can't get mapserver to access
> > any layer files that are outside my server directory. I have images on
> > the htm template file that reference other drives and servers so it
> > doesn't seem to be a rights or permissions problem.
> > Any suggestions?
> > Thanks,
> > Adam Ryan
> > Linn County GIS
> > Oregon
